just installed susp. and car is now Slammed!!!!
Old Feb 4, 2003 | 02:21 PM
WhiteTeg2000's Avatar
Default just installed susp. and car is now Slammed!!!!
This is not what i was looking for. Car was originally on heated factories and rode like azz. So i ordered to h&r cup kit to hopefully come up a little. Didnt happen though, it actually dropped it another half inch. Just got the alignment done and my front has negative 2.9 degrees of camber. So i definitly want to come up some.
Does anyone know if you can run ground control coil-overs with Koni yellows and if so how would the ride be
Old Feb 4, 2003 | 02:27 PM
garados's Avatar
Default Re: just installed susp. and car is now Slammed!!!! (WhiteTeg2000)
gc's can be run on konis, but you'll need the koni-specific version. The ride should be awesome.
Old Feb 4, 2003 | 02:34 PM
Default Re: just installed susp. and car is now Slammed!!!! (garados)
Another ? does anyone know how much it will be to purchase a new front right fork i think i messed up the threads on the end that connects to the shock.
Old Feb 4, 2003 | 02:46 PM
Solipsist's Avatar
I have Konis but I have the Eibach sportlines, the ride is very stiff even on a soft settings. Handles great though. You can adjust the ride hieght perch to your preference. You have to experiment a bit until you get the settings you like, as well as changing the camber again.
Good luck
Old Feb 4, 2003 | 03:07 PM
HondaJon's Avatar
Default Re: just installed susp. and car is now Slammed!!!! (TEXASLS95)
If you're looking for a good ride on the street more than performance, then just get the GC's with the regular street rates on them. Won't provide as high of performance as some higher rates, but will ride fairly well and allow you to adjust the height to you and your alignments liking.
JP
GagnarTheUnruly
Suspension & Brakes
10
Dec 26, 2009 04:59 PM
sh0rt1e67
10
Feb 22, 2009 10:04 PM
cliffsta
Aug 20, 2007 08:03 PM
24hourflipness
Apr 4, 2003 08:02 PM
bretx0r
May 27, 2002 03:42 PM
