Best power adder for B18C
Old Feb 4, 2003 | 01:55 PM
igottab18's Avatar
Default Best power adder for B18C
Hey, I'm new and can't get the search thing to work the way I want it to
So what's the best way to get power out of the B18C after bolt ons safely, and not super-expensive...
How much juice, boost, etc.. can it handle safely from time to time??? Details please
Old Feb 4, 2003 | 01:57 PM
J_Edwards's Avatar
Default Re: Best power adder for B18C (igottab18)
You aren't trying to search hard enough....just search for individual part names...like "intake" "headers" etc....isn't too hard.
Old Feb 4, 2003 | 02:00 PM
igottab18's Avatar
Default Re: Best power adder for B18C (mr. clockwork)
I already have the bolt ons I/H/E Kenji ecu, V-AFC, i'm looking to go to the NEXT step
Old Feb 4, 2003 | 02:02 PM
MK Ultra's Avatar
Be more specific.
Best for what application? Street/strip? Road course?
Best as in how? Cheapest? Most reliable? Most readily available?
And why do you want more power? What modifications do you already have?
Old Feb 4, 2003 | 02:05 PM
igottab18's Avatar
Default Re: Best power adder for B18C (MK Ultra)
Well it's a LS with a b18C so it's heavy
I'm just trying to get mid 13s on street tires...I want something reliable enough for a DD. But I dont' wanna spend 8K.
Apex Header
Comptech Intake
5Ziggen Fireball cat-back
Kenji P-28
V-AFC
Old Feb 4, 2003 | 02:12 PM
MK Ultra's Avatar
Step 1: Ditch the Kenji and the VAFC. Get Hondata. Tune on dyno.
Step 2: Add performance clutch and lightweight flywheel.
Step 3: Add motor mount inserts.
Step 4: Add aftermarket crank pulley. No, it won't blow up your motor.
Step 5: Bump compression 1~1.5 points.
Step 6: Add aftermarket cams.
Step 7: P&P.
Step 8: Add 290~310 cc injectors.
Step 9: With engine not yet put together, take lots of pics to post on H-T under thread titles such as, "bling bling," and "______ goodness."
Step 10: Replace your header and exhaust. You'll probably want something else by now.
Step 11: Tune.
Step 12: More tuning.
Old Feb 4, 2003 | 04:04 PM
itr-j's Avatar
open header
Old Feb 4, 2003 | 04:08 PM
andrewasf77's Avatar
Default Re: Best power adder for B18C (itr-j)
why not some type of cams and cam gears?
Old Feb 4, 2003 | 05:09 PM
igottab18's Avatar
MK Ultra thanks, anyone elsE?
Old Feb 4, 2003 | 05:17 PM
K1R's Avatar
K1R
B18C1 or C5?
C1 for Boost
C5 for NA
Old Feb 4, 2003 | 05:21 PM
Hooch'n's Avatar
cams=
pistons =
compression=
open header=
Old Feb 4, 2003 | 05:29 PM
SurferX's Avatar
Don't you need the P28 and harness like what Kenji provides or some other OBD1 ECU to even use a Hondata in the first place?
Old Feb 4, 2003 | 05:47 PM
Comp97GSR's Avatar
Default Re: Best power adder for B18C (SurferX)
that is the politest post from Mr Ultra I have ever seen
Old Feb 4, 2003 | 05:52 PM
-Whitey-'s Avatar
Default Re: Best power adder for B18C (Comp97GSR)
flywheel
cams
cam gears
dyno it
in that order
Old Feb 4, 2003 | 05:53 PM
igottab18's Avatar
Default Re: Best power adder for B18C (K1R)
K1R- its a JDM B18C
Old Feb 4, 2003 | 05:57 PM
py1188's Avatar
B18C1 or C5?
C1 for Boost
C5 for NA
I would say ditto.
Sounds like you're looking for straight-line performance anyways
Old Feb 4, 2003 | 06:01 PM
TypeR 599's Avatar
Default Re: Best power adder for B18C (py1188)
drag kit..
or be conservative and get jun3's
Old Feb 4, 2003 | 06:23 PM
JDM CTR '00's Avatar
Default Re: Best power adder for B18C (TypeR 599)
Oh Did Alex say something? lol
Old Feb 4, 2003 | 07:54 PM
MHill's Avatar
Default Re: Best power adder for B18C (ChargedSi99)
this is igottaB18........
Im just looking for around a 13.7 on street tires But still wish to autoX the car, so the suspension is coming also......
Old Feb 4, 2003 | 09:35 PM
baonest1's Avatar
hahaha sounds like somthing i did.. oh wait. i did.
Old Feb 4, 2003 | 09:37 PM
TypeR 599's Avatar
what?
Old Feb 4, 2003 | 11:13 PM
deepgreengsr's Avatar
the best power adder is LEARNING TO DRIVE. Most people cant use their car to its full potential, and then buy aftermarket stuff to make it faster, Drive it faster, and when you finally overpower your car , then you can make it faster with headders and stuff.
Old Feb 5, 2003 | 03:30 AM
Ex-ITR5874's Avatar
Instead of pushing power:
Reduce weight, upgrade your drivetrain, get light rims and better tires. Save your money for
Old Feb 5, 2003 | 04:02 AM
NunRacer's Avatar
Default Re: Best power adder for B18C (deepgreengsr)
I agree with what you said but you don't need to spend too much time learning how to go fast in a straight line.
Old Feb 5, 2003 | 04:17 AM
Asahi's Avatar
Default Re: Best power adder for B18C (NunRacer)
Exactly, but look how cool it has become to **** on someone's parade and lecture about learning to drive. . .
