Which way according to hasport ?
Old Feb 4, 2003 | 01:21 PM
RCautoworks's Avatar
Default Which way according to hasport ?
For wiring an ecu, hasport says, To orient the plugs properly when using this diagram hold the plug with the wires facing away and the clip on top. Ok so I made this picture to better explain my question, when I am listening to hasport do I look at side A or side B ?
Side A is like the back of the clip where the wire goes into the clip, and sie b is like where the wires go into the ecu.
[Modified by 90blackcrx, 4:25 PM 2/4/2003]
Old Feb 4, 2003 | 02:42 PM
raene's Avatar
Default Re: Which way according to hasport ? (90blackcrx)
B
Old Feb 4, 2003 | 03:25 PM
sgT's Avatar
sgT
Default Re: Which way according to hasport ? (raene)
to figure out pin #s you look from side A.
Old Feb 4, 2003 | 10:01 PM
Default Re: Which way according to hasport ? (sgT)
So is it side A or side B, I thought it was side A.
Old Feb 4, 2003 | 10:41 PM
raene's Avatar
sgT is right, for the pinouts you look from side A, but from HASport's instructions it seems like B
Whatever, just use A
[Modified by raene, 11:41 PM 2/4/2003]
Old Feb 4, 2003 | 11:43 PM
But if you look at them from side B the wires would be coming at you, but if you look at it from side A, the wires are going away from you. So for hasport instructions is side A right.
Old Feb 5, 2003 | 03:09 PM
Anyone else.
Old Feb 5, 2003 | 04:50 PM
90_Civic_Hatch's Avatar
side A to figure out the pin outs.
EDIT: I'll try to explain here, for C12 (pinout) you would look at the C clip, point the clip as though you are goining to plug it in to an ecu that is in front of you (so all the wires are between you and the clip) then look at your pin out chart and find the location on the clip.
[Modified by 90_Civic_Hatch, 1:54 AM 2/6/2003]
sevenfc
Apr 16, 2009 02:48 PM
iheartamy
Dec 23, 2006 08:43 AM
hybrid1990crx
Nov 19, 2004 11:00 AM
Firedrake
Oct 30, 2002 04:56 AM
Malgerus
May 6, 2002 09:25 AM
