DC Header Part# Question for D15B7
Old Feb 4, 2003 | 08:00 AM
Mocky57's Avatar
Default DC Header Part# Question for D15B7
Before the flames coming flying, I did do a search.
I found a DC 4-2-1 Header for sale Part#hhc5013.
Checked DC's site to check on whether it would fit my EG. It lists 3 headers, under ceramic, 3 under SS. All say they fit 92-00 Civic. What's the difference between the 3? 4-2-1, 4-1, and ?? Will an HHC5013 fit my D15B7 motor? Thanks in advance.
[Modified by Mocky57, 12:01 PM 2/4/2003]
Old Feb 4, 2003 | 09:46 AM
Mocky57's Avatar
Default Re: DC Header Part# Question for D15B7 (Mocky57)
any ideas?
Old Feb 4, 2003 | 09:49 AM
Patrick's Avatar
Yes, they will all fit but you will have to lengthen the o2 sensor wiring and you wont have a cat, so your exhaust will be loud as hell.
[Modified by gsr_vx_hatch, 6:49 PM 2/4/2003]
Old Feb 4, 2003 | 09:52 AM
Mocky57's Avatar
Default Re: DC Header Part# Question for D15B7 (gsr_vx_hatch)
uh.err... losing cat and lengthen o2 sensor wiring .. hmm.. just checked.. lists this header as 4-2-1 2piece ceramic header. I'll lose my cat as well? thanks for the info!
Old Feb 4, 2003 | 01:08 PM
Patrick's Avatar
Never mind I was thinkin of the wrong engine, Im not sure about the dx but I think its just a bolt-on and go affair.
Old Feb 4, 2003 | 01:16 PM
Eee Pee's Avatar
1 piece is lighter...
Old Feb 4, 2003 | 01:27 PM
Mocky57's Avatar
thanks just got a little nervous there.
so..i guess i should be all good to go..
what's the difference between 2piece 4-2-1, and the one piece 4-2-1 ceramic header? (besides one is 2 pieces, 1 is one piece).
Old Feb 4, 2003 | 01:30 PM
Eee Pee's Avatar
See my post above?
Old Feb 4, 2003 | 02:33 PM
93civdx's Avatar
Default Re: DC Header Part# Question for D15B7 (Eee Pee)
yeah just bolt it on. have one on my 93 4 door but its a 4-1 1 piece. although i do have a leak where my header meets the cat. but it isnt too bad.
Old Feb 4, 2003 | 09:08 PM
Mocky57's Avatar
See my post above?
so only difference was weight?
no biggie there
thanks!
Old Feb 5, 2003 | 02:50 AM
D16Z6racing's Avatar
Who ever said you lose your cat is lyin' out their a$$.
I have a 4-2-1 ceramic 1 piece on my 93 hatch. Bolted right to the cat.
And <U>you</U> don't have to lengthen any o2 wires. DC sends an extension wire that plugs right into your existing wires.
One more thing.....It doesn't matter from 1 piece to 2 piece or 4-2-1 to 4-1. And it doesn't matter 1.5 to 1.6 SOHC (92/95). I had this header on my CX motor, swapped in a DX, then swapped a SI......worked perfect for all.
[Modified by D16Z6racing, 3:55 AM 2/5/2003]
teggrl
Oct 19, 2007 08:03 PM
SleepnCiViC
Dec 12, 2003 08:40 AM
SpoonboyChoi
Mar 16, 2003 05:02 PM
solkid
Apr 9, 2002 09:33 AM
Eg6_JDM
Apr 2, 2002 06:42 PM
