Need help... Electricity dies often while driving!
Howdy. folks! I'm a stranger here but I feel quite comfortable.
I've driven 97 GSR (no mod except tires and wheels) for 2 years here Atlanta. I love this car.
Well, I hope I will see you guys often here.
BTW, recently, I have a few problems with her.
1. The electricity cuts and runs again often while driving! The radio turns off for a half second and ABS warning turns on. It's getting worse now! RPM suddenly drops like it is going dead when the electricity dies for a few tenth second.
I can't figure out what is the problem.
2. My window rattles when it's open half way down. When it rains and the window gets wet, it makes severe sound while opening or closing.
Well, I would like to know how to fix these.
I looking forward to hearing from you, guys!
RIP Adrea Aunie
[Modified by Eric@Atlanta, 10:56 AM 2/4/2003]
Well, I hope I will see you guys often here.BTW, recently, I have a few problems with her.
I can't figure out what is the problem.2. My window rattles when it's open half way down. When it rains and the window gets wet, it makes severe sound while opening or closing.
RIP Adrea Aunie [Modified by Eric@Atlanta, 10:56 AM 2/4/2003]
Sounds like it could be an alternator? How long has this been happening? The voltage regulator could be bad as well.
I'd double check all your connections, especially around your battery right now. Make sure they're clean and solid. If that doesn't fix it, I know places like AutoZone will test your alternator for free.
EDIT: for the window problem...take off the door panel and tighten every bolt you see that holds the track, sounds like one is loose (happened to me a few times on my 95 GSR). It's easy to do.
[Modified by cheezthis, 9:18 AM 2/4/2003]
Thank you, all guys.
I'll check the alternator and connections sometime soon.
BTW, I couldn't find any answers for window problem by search function here..
Anybody has any idea on it?
wasssup
Dec 1, 2007 08:14 AM
Magaton00si
16
Oct 1, 2006 11:21 AM
