tips on stuck screws on brake rotors
Old Feb 3, 2003 | 10:27 PM
SSBP DC2's Avatar
Default tips on stuck screws on brake rotors
facts:
-this is about the 2 phillip screws that holds the rotors to the hub.
-my screws are virgin screws from the dealer (has never been touched, i.e. no previous rotor work)
-i tried for an hour with an impact tool and couldn't get the damn thing to twitch
-this is with a huge mallet and a snap on impact driver
-yes i'm going counter-clock wise, and yes i'm hammering it very hard for those who may want to make a funny.
?: Does any one have any tips for me?
thanks
-demitri
Old Feb 3, 2003 | 10:32 PM
tC_Dragon's Avatar
Default Re: tips on stuck screws on brake rotors (SSPB DC2)
well i removed those same screws off of my 94 LS wit a craftsman impact tool from sears and it was the easiest part in my opinion. But EVERYONE else has had exactly the opposite experience from me. I just kind of gave the driver slight counterclockwise pressure as i hit it with the hammer. And i used a regular carpenters hammer not a mallet.
Old Feb 4, 2003 | 01:35 AM
tilt's Avatar
I have the same problem. Tried the impact driver /w hammer and it doesnt budge cuz of rust. I'm going to try with a 10lb sledge next and if that doesnt work im gonna drill the screws out.
facts:
thanks
-demitri
Old Feb 4, 2003 | 04:03 AM
Chris L's Avatar
Just drill them out and forget about them. Plenty of people run without them at all.
Old Feb 4, 2003 | 05:01 AM
shockwave's Avatar
Default Re: tips on stuck screws on brake rotors (Chris L)
So are your lug nuts supposed to hold on the rotors? This doesn't affect the caliper and breaks? Just curious.
Old Feb 4, 2003 | 05:42 AM
Solracer's Avatar
Default Re: tips on stuck screws on brake rotors (shockwave)
I drilled them out on my Del Sol, and my Wifes Integra both cars have been on track (VIR, Summit CMP) and no problems, imho those little screws are there just to hold the rotor in place when you change tires becaues with your wheel bolted to the lug nuts there is now way they are going any where.
Old Feb 4, 2003 | 05:49 AM
Solipsist's Avatar
I've had to Dremel them out in the past. A friend of mine just did it on his wife's civic. That was the only way to get them off.
Old Feb 4, 2003 | 06:22 AM
jxdxpx's Avatar
I had the same probelm. I got them out by using a craftsman impact tool to loosen them. Then I still couldn't get them out so I bought an electric impact wrench and then they came out easy. I found that I had to use both tools. When I got them out I had to replace them because the heads were stripped and I was able to find new screws at a True Value hardware store.
HTH
Old Feb 4, 2003 | 02:57 PM
SSBP DC2's Avatar
Default Re: tips on stuck screws on brake rotors (jxdxpx)
thanks guys
i'll probably give it a go again sometimes this week with impact/mallet
if not i'll just drill the SOB out
-demitri
Old Feb 4, 2003 | 03:03 PM
HondaJon's Avatar
Used an impact driver and hammer on my friends DA.
Got the one from craftsmen, and it worked like a charm.
If that fails to work, then things become alot harder and more painful.
Good Luck,
JP
JBirch_97Prelude
Jun 25, 2008 05:25 PM
zirac50
May 3, 2007 05:15 PM
Rywire
10
Jan 12, 2004 11:50 AM
Drag-On23
Oct 28, 2003 08:29 AM
Scooby
Jan 15, 2002 10:22 AM
