Question for MTK or any knowledgable HID consumer
Old Feb 3, 2003 | 02:11 PM
spankey167's Avatar
Default Question for MTK or any knowledgable HID consumer
Hey MTK,
Sup man gotta question about purchasing 4300K HID bulbs. Well right now i've got a d2r Hella ballast system setup with 8000K. I've heard what u've said about how 4300K are way better, so today I went checkin at some car shops with no luck. Even gave a call to the manufacturer that made my system (falcon) but they only carried the 8000K that came with my system. I know your from Socal and wondering if you knew any places that would carry 4300K HID bulbs? Thanx in advance.
Old Feb 3, 2003 | 02:24 PM
zer0zer0 TypeR's Avatar
Default Re: Question for MTK or any knowledgable HID consumer (spankey167)
what kind of ballast does the hella system use? if it's phillip's you can just order a d2r bulb from phillip's which i belive are around $150 or so. but if the hella kit uses a panasonic or other type of ballast than you'll run into trouble.
Old Feb 3, 2003 | 02:47 PM
spankey167's Avatar
Default Re: Question for MTK or any knowledgable HID consumer (zer0zer0 TypeR)
Hella IS the ballast system. From what i know, the 3 main ballast systems ARE Hella, Osram, and Phillips. Whats wrong with panasonic? Why would there be trouble?
Old Feb 3, 2003 | 07:50 PM
spankey167's Avatar
Bump for MTK
Old Feb 3, 2003 | 11:28 PM
ILOVEGIRLS's Avatar
https://honda-tech.com/zerothread?id=397762
there some links to some stuff there.
Old Feb 3, 2003 | 11:32 PM
why? because phillip's, osram, panasonic, or hella ballasts don't usually interchange parts. i used to have a panasonic ballast, and the phillip's ballast, it's not possible to use the panasonic ballasts with the phillip's bulbs without some kind of harness if that is even possible.
Old Feb 4, 2003 | 02:07 AM
SubieWagon's Avatar
I had 4100K HID bulbs in my Civic previously... They're bright and are in pure white color compared to my friend's 6000K HID bulbs, which are in more bluish color.
Check out www.suvlights.com. hth
Old Feb 6, 2003 | 03:11 PM
MTK Kommander's Avatar
Default Re: Question for MTK or any knowledgable HID consumer (DIESEL8118)
whoa.. i cant believe nobody linked me to this thread..
anyways.. here you go..
Pacific Microlite
(310)364-5219
ask for Bob.. tell him what kinda bulb you need for which car and he will UPS them to you within 2 or 3 days for i think $125 a bulb..
Mr.DC2TurBo
Mar 9, 2003 02:24 PM
