H22a swap?
Old Feb 3, 2003 | 01:01 PM
gsrhatch530's Avatar
Default H22a swap?
I am getting a H22a swap and the shop said they had to buy a crank sensor cause the JDM engines don't come with them and ours do. Has anyone herd of this?
Old Feb 3, 2003 | 01:03 PM
stockludesi's Avatar
Default Re: H22a swap? (gsrhatch530)
i'm not quite sure about this one, considering the japanese, had more advanced, and cooler options on their ludes, i would look into this more, it kinda sounds a little fishy
Old Feb 3, 2003 | 01:15 PM
Default Re: H22a swap? (stockludesi)
I need to find out if I am getting screwed or not
Old Feb 3, 2003 | 02:00 PM
Cottonwoodz's Avatar
I think if its a Pre-96 motor(OBD1). But then again I could be wrong.
Old Feb 3, 2003 | 02:43 PM
prospeed's Avatar
You will need the cranksensor if you plan on running a US ecu. You will need more then the crank sensor. You will need the oil pump that holds the crank sensor. The 96 and up jdm engines do not come with cranksensors. You can bypass it by running a jdm ecu. It would work fine.
Old Feb 3, 2003 | 03:23 PM
Default Re: H22a swap? (prospeed)
I am going to be running a US ECU. Is this going to read any different than the jdm ecu?
Old Feb 3, 2003 | 11:23 PM
prospeed's Avatar
You can not run the us ecu because it reads crank trigger. Thats why u need to use a JDM ecu.
Old Feb 5, 2003 | 06:37 PM
That is why they put on the crank sensor, so that the US ecu can read the sensor. Is he filling me full of smoke or is he right.
Old Feb 5, 2003 | 08:07 PM
papa_smurf's Avatar
on US OBD1 cars the sensor is part of the distributor, on OBD2 cars it is on the crank. all he needs to do is swap over to a US OBD1 dizzy he should be fine. plus its a lot easier.
edog
15
Feb 1, 2009 05:48 PM
tyflip2
Dec 5, 2003 08:32 AM
BABYGIRL ITR
Jun 9, 2002 11:17 PM
