Thermostat Questions....
Old Feb 3, 2003 | 12:30 PM
Brett-Pac's Avatar
Default Thermostat Questions....
Hey everyone, im changing my thermostat today, but I have a few questions, I know to take out the drain plug in the bottom of the radiator and drain it, and then to take off the hose connected to the housing of the radiator. But my question is, when I drain the coolant, will there be any left in that hose that is connected to the housing? Also, after completing the task and refilling it, what will be a good way to test the thermostat?? Please respond with all good suggestions....thanks guys
Old Feb 3, 2003 | 02:11 PM
sharkcohen's Avatar
Default Re: Thermostat Questions.... (Brett-Pac)
Yes, there will still be quite a bit of coolant in the hose, so expect spillage. The only way I can think of to test the t-stat is with a datalogger or a coolant temp gauge to view your actual coolant temp. Is this a lower temp t-stat?
[Modified by sharkcohen, 11:12 PM 2/3/2003]
Old Feb 3, 2003 | 02:42 PM
tominos's Avatar
Default Re: Thermostat Questions.... (sharkcohen)
just let the car warm up, if its working, then the lower radiator hose will be hot.
Old Feb 3, 2003 | 07:50 PM
Furry
Guest
Posts: n/a
if the heat works the thermostat is good, if it dosnt work then the thermostat is bad.
Old Feb 3, 2003 | 08:01 PM
Cottonwoodz's Avatar
Default Re: Thermostat Questions.... (Furry)
What happends if its stuck open?
Old Feb 4, 2003 | 08:13 AM
Ludester's Avatar
Default Re: Thermostat Questions.... (Cottonwoodz)
If it is stuck open then its shot. You are in need of a new one. Usually signs to tell you this are: If your car taking awhile to heat up. Or when it does the heat isnt very hot.
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
dlstech
16
Dec 12, 2012 03:04 AM
Uncle Ben's
Jan 20, 2008 08:22 AM
turbotime
Oct 11, 2005 10:08 PM
dkdjlf
Aug 14, 2003 10:34 AM
