13.8@99mph on street tires
I finaly ran my car this weekend.13.8 @ 99mph on street tires.Left on an idle only a 2.17 60.Anything more than an idle blew the tires.Still havn't tunned the car that well.I think there is about 15 to 20 hp hiddin in there.I was pretty stoked though .I think w/ a little tunning and some slicks I could hit a low 13 maybe even a 12????
Ummm I think you need to buy some drag radials and go to the dyno.
I am running quicker times with a STOCK C5 motor on an Si ecu in an EK. I dyno'd it in this condition 163.5whp.
I think with tuning you have a 12.50-12.80 car easily. You *should* hit 210-215whp with your setup once tuned maybe more.
Good luck
Good luck
Thats the plan.But I will be on the boost w/in a month.Dont want to waste the money on a n/a tune up win I will have to spend a ton to tune the turbo set up.
[Modified by COLORPROS, 9:09 PM 2/3/2003]
i think a 2.1 60ft on street tires is great traction....with your set up thats amazing traction for street tires....also what model HATCH do you have.
Steve
Steve
AGAIN!The car is not tunned at the moment.I know it will be much faster than this.It should also pull goood above 8500 and its not right now.
VX..yea man you got alot of tuning to do.....you have the setup to do a low 13 and with some drag radials high 12's....get that tuning done....hopefully that will help.
Steve
Steve
I will just talk to you through the PRIVATE MESSAGE feature....its better then making this post really long. I just PMed you.
Steve
Steve
Good luck
Good luck
Not trying to be negative here but thats slow as crap. I ran faster than that in my stock weight ITR with only and intake, header, and no PS belt. I would think a bolt on B18C5 hatch would be hitting low 13's easy at well over 100mph. I would get that thing on the dyno ASAP because something is definitely wrong.
Just found about 25 hp.and revs up and over nine grand w/ease.Before it was tuned wrong and struggled after about 8200.Im sure I will get a way better time now.
I would have to agree that something is definitely not right. We had ITR motor in a 00 Si and ran 13.7 with a clogged converter. We also built a CX hatch with stock ITR motor and it went 13.3 @105 on street tires.
yaaj1320
May 20, 2007 08:45 PM
