changing gauges in honda del sol 93 si
Old Feb 2, 2003 | 06:57 PM
lucint's Avatar
Default changing gauges in honda del sol 93 si
does anyone know how hard it is to get the front dash off to install the new gauges like how much harder is it then in a civic and if u know how do i get it off????
Old Feb 2, 2003 | 08:04 PM
93EH6
Guest
Posts: n/a
Default Re: changing gauges in honda del sol 93 si (lucint)
If you are talking gauge overlays it is very easy i haven't done it in a while so i don't remember everything but on a del sol you take out the two screws above the cluster and the three holding it in from there i forget i just had to do that today to fix my tach hope this helps some
Old Feb 2, 2003 | 08:08 PM
ShortbusEK's Avatar
in a del sol its almost tooooo easy to take out the guage cluster.. the part on top of the dash above the guage cluster that has the switches for the cruise control the fog lights and stuff like that.. all you gotta do is take out the two screws on the bottom.. then pop out the switches.. if your sittin in the drivers seat just pull them toward you and they slide right out... then that piece is just held in by clips after you have done the first two things so just pull it off.. then there are 3 screws holding the guages in.. one on each side.. then one on top.. take thsoe out and then pull the cluster out.. and your done..
Coupe16vt
Jun 3, 2018 03:05 PM
Jack 4TT4CK
Sep 13, 2013 07:01 PM
ChevelleSSLS6
Nov 8, 2009 08:20 PM
qat727
Dec 2, 2005 10:15 PM
