ITR Sway Bar? Yes I have already searched the fourms.
Old Feb 2, 2003 | 06:29 PM
dgdarien's Avatar
Default ITR Sway Bar? Yes I have already searched the fourms.
So I have a '00 EX Civic coupe. And BSQ's website states that I would need the following.
Here are the Acura parts that will be need:
1.) 52300-ST7-Z01 rear swaybar ($57.30)
2.) 52315-ST7-Z01 swaybar bushing ($3.57) (2 needed)
3.) 52308-SS0-000 bushing bracket ($4.86) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.41) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($3.98) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($1.98) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.08) (2 needed)
BUT it says
These installation instructions are intended for following cars:
Acura Integra ('94-'01)
Honda Civic ('92-'95)
Honda Del Sol ('93-'97)
Are these still the exact same parts that I need?
Old Feb 2, 2003 | 07:07 PM
EricUSC's Avatar
Default Re: ITR Sway Bar? Yes I have already searched the fourms. (dgdarien)
I would buy this kit if I were going to add an ITR rear swaybar:
http://www.beaksproducts.com/ek-quickswap.html
It comes with everything you need for a Civic Si, including an ITR swaybar, but since you have an EX, just contact them and they will be able to provide you with the additional items needed, like the endlinks. This kit comes with subframe reinforcement, which is highly recommended since larger swaybars can rip out of the subframe during hard cornering. Of what I hear on the forums, Beaks Products has great customer service.
Old Feb 2, 2003 | 07:08 PM
EGO's Avatar
EGO
search some more. you might have existing parts on your car similar to that of 94-01 integras. i dunno.
Old Feb 3, 2003 | 11:54 AM
dgdarien's Avatar
Default Re: ITR Sway Bar? Yes I have already searched the fourms. (E-H-2)
Anyone know for sure? I wouldn't want to buy parts that I don't need.
Old Feb 3, 2003 | 11:57 AM
SlippylesKB's Avatar
Like Eric said, I would check out the the beaks kit. We put an ITR bar on 98 GSR and with the Beaks kit it was simple as pie, the only concern is you have to drill... all depends on how you feel about that. But contact beaks... I thought that your platform was the same as a 94-01 Integras... do EX's have disc brakes? If so then it should be the same (all I know from personal experience is Integra tho)
Scott
Old Feb 3, 2003 | 12:16 PM
WalkEX99's Avatar
Default Re: ITR Sway Bar? Yes I have already searched the fourms. (SlippylesKB)
I'm looking into this also....I have a 99 EX. Will I need to drill out the LCA's for the install?
Old Feb 3, 2003 | 12:18 PM
sohc_boy's Avatar
Default Re: ITR Sway Bar? Yes I have already searched the fourms. (WalkEX99)
should have the proviosions for the sway bar already i have a 99 cx and it is setup for the bar even tho it doesn't have one.
Old Feb 3, 2003 | 12:23 PM
You just drill a small hole on the subframe for the 2nd hole of the bushing plates (on the beaks kit). Not a big deal in my opinion.
Scott
volcomstoned
Oct 31, 2006 05:49 PM
TurboBumblBee
11
Mar 31, 2003 08:06 PM
skunkintegra
Feb 26, 2003 01:04 PM
roninb18
Jan 30, 2003 06:09 PM
gsr94
Aug 15, 2001 03:30 AM
