help me out
lately and now its gettin worse but when i go in first the car kinda feels like it has fouled plugs .. but it only happends in the begining of first and second ..it kinda sputter then goes .. i changed the plugs changed the rotor . i dunno Fuel problem? 02 problem? spark problem?
no thats not it . i just changed the cap, rotor, and external coil, new plugs . im think o2 now . maybe the dizzy itself or ignitor? ....?
Man your problem sounds exactly like mine although mine is an auto but same thing when I am first taking off its real sluggish I have changed the plugs,wires,cap,rotor,pcv,O2,fuel filter,and the air filter and still having the same problem. I was also thinking ignitor but the more I read about it the more it seems that if the ignitor is going bad it would throw a code and I dont have any codes??!! I may try the EACV and see if that helps but I am in the dark on what the problem is??
I heard of this problem in accords also. One accord owner said that he adjusted his timing and it ran fine after that.. I dont see how that would make the car bog specifically in one RPM range, but you could give it a shot.
eacv . hmm . i do need a new one .. ill try that tommrow.
