grining in the gears???!!!!???
on occasion when shifting into reverse, from a dead stop at idle, with clutch fully in....a terrible grinding sound occurs like i am trying to shift without use of clutch....
also a few times while driving i will shift into 3rd or 5th and the same grind will happen.....whats up with this....also somtimes i need to press and release the clutch a second time before the engine will turn on.....
ust a note....i have aftermarket pedals....that have 1/2 inch screw ont he back would this half inch make a difference....????
N21
http://www.ct.streetracing.org
NOS_21@mail.streetracing.org
AIM: GoSpdRac3r
pedals dont matter. transmission needs fixin. go to a shop. simply.
unless you know a lot about tranmissions...and you could fix your syncro problem... but i doubt it...
first off, what kind of tranny is it? second, try changing the fluid with MTF from the honda dealer...use 2 quarts if it's a B16 tranny. if not, then you might wanna get the tranny looked at which means = $$$...
could be bad synchros...from the way you described it...
My transmission did that just before the clutch went out.
I'd check out the fluids first make sure there toped off (clutch fluid,tranny fluid)
Also make sure you dont have a clutch master cylinder leak that could also be a cause of grindin or bleed your CMC.
Hope this helps a little
