ARP Head Studs worth it in my setup?
Old Feb 2, 2003 | 10:33 AM
93LudeVtec's Avatar
Default ARP Head Studs worth it in my setup?
I am trying to get my N/A set-up done as fast as possible, will head studs help me at all? I searched and some people say it helps keep the head toghether with boost, I plan to run all motor 98% of the time and maybe use a 85 shot for one or two runs down the 1320 a week. Thanks for the help. Andrew
Old Feb 2, 2003 | 11:49 AM
illi Adik's Avatar
Default Re: ARP Head Studs worth it in my setup? (93LudeVtec)
You might as well, they will make your Head that much stronger, even if it is all motor. My guess is the engine will still be run hard.
Old Feb 7, 2003 | 12:08 AM
XES's Avatar
XES
Default Re: ARP Head Studs worth it in my setup? (Jackson4Door)
I'm still running stock head bolts with no problems at 22+psi...
If they are at your disposal then go for it...but don't loose sleep over it i.
Old Feb 7, 2003 | 02:05 AM
xsolidcellx's Avatar
Default Re: ARP Head Studs worth it in my setup? (XES)
The head bolts makes it alot easier to assemble the motor. Its not extra expensive so might as well just get it. I say you shoudl get it if you have the funds.
ral24_hct
Aug 6, 2010 07:51 AM
Incognito
Sep 18, 2009 12:52 PM
Egpower88
Jul 20, 2009 08:17 PM
TegraD
Jan 21, 2009 07:20 PM
bow tie
Oct 21, 2008 12:03 PM
