swaybar endlink part #, or Carland Acura's suspension diagram?
Old Feb 2, 2003 | 10:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default swaybar endlink part #, or Carland Acura's suspension diagram?
Does anyone have the part number for the GS-R rear swaybar endlinks, or happen to have a copy of Carland's Integra rear suspension diagram saved? My friend needs a pair of the endlinks to put an ITR swaybar onto his Civic, but the diagram on the Carland site does not work, only a red X Thanks for any help.
*edit* this is the site, as you can see the diagram doesn't work. Could the endlinks be number 6 on the list, 2 required, $18.81 each? I wonder if that would include the bushings and collars if I ordered #6?
http://www.acuraautomotiveparts.net/...REAR+LOWER+ARM
[Modified by PatrickGSR94, 1:05 PM 2/2/2003]
Old Feb 2, 2003 | 10:44 AM
ebelp's Avatar
Default Re: swaybar endlink part #, or Carland Acura's suspension diagram? (PatrickGSR94)
I'm almost positive that's the right part you're talking about. I'd call them to be sure though. They probably don't even know that pic isn't working.
Old Feb 2, 2003 | 11:01 AM
Community Builder
Default Re: swaybar endlink part #, or Carland Acura's suspension diagram? (ebelp)
well what I'm wondering if any other parts come with that #6 on the diagram. BSQ lists endlink bushings and collars as needed when putting the ITR bar on a non-R Integra. But since my friend will be needing the entire endlinks for his Civic, I'm wondering if he would still have to order the bushings and collars or if they would be included with the endlinks (you know how some diagrams show individual parts, and then certain groups of parts might be circled with a number). That's why I need to see the diagram.
Old Feb 2, 2003 | 03:52 PM
slomob18b's Avatar
i don't know if this might help, but i have heard that the 4dr integras have the same size rear swaybars as gsr's. don't take my word for it though
EDIT:nevermind, the part numbers are not the same for the endlinks..
[Modified by slomob18b, 4:55 PM 2/2/2003]
Old Feb 2, 2003 | 06:13 PM
BSQ's Avatar
BSQ
First, the part number for the endlink is 52303-ST7-Z00, which is part #6. You will still need to order the endlink bushings and endlink collars.
Old Feb 2, 2003 | 07:58 PM
Community Builder
Default Re: swaybar endlink part #, or Carland Acura's suspension diagram? (BSQ)
Thanks alot!
Civicman86
May 5, 2007 08:37 AM
slim9300
Apr 17, 2006 07:06 PM
Sport_Injected
Feb 27, 2004 11:17 AM
