Swapping engines with wife need help.
Old Feb 2, 2003 | 09:17 AM
Hulkbuster's Avatar
Default Swapping engines with wife need help.
Okay my wife has a 89' Dx sedan and she has well over 200K on the motor. I have A HF crx and mine has like 130K. I was going to swap the engines. How hard will it be? Like beside swapping the engines what else will I have to do? I am ppretty sure that I will have to swap the ECU's right? And after the swap I'm converting the D15B2 to MPFI. But as far as the swapping of the engines what will I have to do?
Old Feb 2, 2003 | 09:56 AM
slowman's Avatar
I took way too long
Default Re: Swapping engines with wife need help. (Hulkbuster)
what engine will you be swapping in? a little more detail would be nice.
Old Feb 2, 2003 | 11:52 AM
Hulkbuster's Avatar
Default Re: Swapping engines with wife need help. (slowmanEF)
Okay sorry for not clarifying what engine I was gonig to drop into the HF. I am going to for the time being drop in a D15B2. The engine from the 89' DX. Okay now how does it roll from here?
Old Feb 2, 2003 | 12:18 PM
altoid's Avatar
its easy, mounts are the same, just disconnect the harnesses from each car, and from all periphrial devices, put a hydro jack under the tranny jack plate, lower the thing, roll over to other car, and voila you've got it, just jack up into the car from bottom, put the bolts in the mounts and take a break come back and connect the harness to everything. It pretty simple, just kinda time consuming. good luck.
Old Feb 2, 2003 | 12:26 PM
tdc's Avatar
tdc
ok i gotta ask why are you doing this swap .. if the wifes car need a motor why not change it with a used motor and leave the crx a lone..
Old Feb 2, 2003 | 02:10 PM
USDM 4G VTEC's Avatar
why dont u just pick a A6 or a SOHC VTEC for cheap..
ti will be less trtouble than just swaping those 2 lil shitty engines... plus she will hate having the HF engine over the DX...
Old Feb 3, 2003 | 08:17 AM
hondaki33er's Avatar
Yeah, why don't you just found a used motor to swap into her car. Sounds like a lot of extra work to swap both engines out? Did I read that right?
Old Feb 3, 2003 | 08:43 AM
crxgurlllll's Avatar
Default Re: Swapping engines with wife need help. (altoid)
WIRING IS NOT PLUG AND PLAY!!!!!!!!!!!
the hf motor is MPFI
the dx motor is DPFI
Old Feb 3, 2003 | 09:52 AM
Speed PHreak's Avatar
Default Re: Swapping engines with wife need help. (crxgurlllll)
Thank you, Also the HF ECU has a good many more little functions. The ECU has inputs, for EGR, heater activity, reverse on/of, shift-up output. Also it's a MPFI ECU, whick mean you'd have to wire all the necissary parts into your DPFI(DX) harness to make it even run.
It's gonna be easier to swap in another DX engine or an D16A6. The HF will just be a **** load more complicated and you wife will prolly bitch about how the car won't "go" anymore........... b/c it's a 62hp engine trying to pull a 2400lbs car.
Old Feb 3, 2003 | 11:51 AM
Hulkbuster's Avatar
Default Re: Swapping engines with wife need help. (Speed PHreak)
Well put! I didn't think about the weight of the cars. I was saying in all my other threads that I found a place that is selling the SOHC ZC for like $455 shipped to my door. That's pretty damned good. So I will probably just let her keep the D15B2 until it goes all the way out. And then probably switch it for another D15B2 or possibly find another SOHC ZC for her. So I guess we can trash this thread. I appreciate the info clarification by you and CRXGURLL! You two are pretty informative!
Old Feb 3, 2003 | 12:16 PM
What the board's here for. Beside's can't let all this unless Honda knowledge go to waste, now can I?
Old Feb 3, 2003 | 12:34 PM
altoid's Avatar
[Modified by EE4, 5:10 PM 2/3/2003]
KyonMechburg
Aug 3, 2018 05:36 PM
g_tech9
Classic Hondas
Aug 8, 2007 06:44 AM
dipillo
May 1, 2005 01:11 PM
SystemAddict
20
May 1, 2002 01:46 PM
