rear tranny bracket, where do i buy one?
If you the B-series you are installing is not either a 89-91 Sir or 90-93 Integra then you will need a different engine bracket to fit the Hasport mount kit. The part number for the first generation B16A bracket is 11910-PR3-010. With this bracket you can use our mount kit to install the B16B, B18B, B18C, B20B and B20Z.
11910-PR3-010
does anyone know where i can buy that?
11910-PR3-010
well u got to switch to hydro also...
What mounts kit are you using to put the b16 in your car? Im pretty sure you need the rear 90-93 Teg Engine braket.
well im guessing the reason why the rear tranny bracket wont bolt up using hasport mounts for any 2nd gen b-series is cause of the hydro tranny. i guess the simplest way is to just bolt up a cable tranny....
[Modified by MnC CRX, 3:49 AM 2/2/2003]
im just going on what hasports instructions said
If the B-series you are installing is not either a 89-91 Sir or 90-93 Integra then you will need a different engine bracket to fit the Hasport mount kit. The part number for the first generation B16A bracket is 11910-PR3-010. With this bracket you can use our mount kit to install the B16B, B18B, B18C, B20B and B20Z.
I am putting a JDM B20B in... So it says to use that instead......
it says
The correct rear bracket is from an 89-91 SiR or 90-93 Integra, part number 50827-SK7-020. Thats if im putting a B16 or B18A only, not a B16B, B18B, B18C, B20B and B20Z.
It has nothing to do with hydro tranny, it has to do with motor position.
it says
iluvmyef9
Apr 3, 2008 12:32 PM
Power Rev Racing
Jul 17, 2005 06:34 PM
