My exhaust rattles!
Old Feb 1, 2003 | 08:31 PM
ih8danoles's Avatar
Default My exhaust rattles!
My stock exhaust started rattling last night.. I dont know what caused it. When i get ready to start moving and give a little rev, the thing over the catalytic converter rattles. This ever happened to anyone else, and what can i do to fix it? Thanks
Old Feb 1, 2003 | 08:38 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: My exhaust rattles! (95civicD16Z6)
Mine does too, sounds so Dirty.
Im getting a catback soon, and taking off the heat shields.
Old Feb 1, 2003 | 08:42 PM
ih8danoles's Avatar
Default Re: My exhaust rattles! (SpoonSportsEH2)
will everything still work right if i take off that heat shield? I tried but couldnt un-bolt it... but i can try harder if it doesnt mess anything up or make it louder
Old Feb 1, 2003 | 08:43 PM
tominos's Avatar
maybe you got a rock inbetween the heatshield and the cat. unbolt the shield and see.
Old Feb 1, 2003 | 08:45 PM
speedaholic92's Avatar
Default Re: My exhaust rattles! (tominos)
does anybody this wierd sound coming from the exhuast?....like popping....especially just after parking your car?....mine is very annoying
Old Feb 1, 2003 | 08:47 PM
rob_d16y8's Avatar
Default Re: My exhaust rattles! (speedaholic92)
I think my rattling on my civic is the cat going out. It sounds like a marble in a tin can. Ting-ting-ding-ting! Oh, it drives me nuts everyone morning!
Rob
Old Feb 1, 2003 | 08:57 PM
GTlvr82's Avatar
This used to happen to my car and I sold that but I have NO idea what the problem was...seemed like a fuel problem or maybe a timing problem...im not too sure cuz I sold it right after it started happening. Ask the gurus on the sight...they would probably know .
Old Feb 1, 2003 | 11:14 PM
AWD: Jeff's Avatar
Default Re: My exhaust rattles! (GTlvr82)
try removing your heatsheild for your cat. thats what happen to me. and i found out that i cracked my heatshield. but ever since then ive goten a hi flow, but now it sounds different. thats a different story.
Old Feb 2, 2003 | 12:40 AM
JforJonathan's Avatar
maybe its a hanger hitting
Old Feb 2, 2003 | 12:42 AM
DSC's Avatar
DSC
From the heat. The metal expands when hot. Goes back to normal as it cools.
Old Feb 2, 2003 | 12:47 AM
SlippylesKB's Avatar
Default Re: My exhaust rattles! (DSC)
Mine does this too, I believe it's the heat-shield. I wish I could take it off but I'm up at school now. I'm going home next weekend to work on her, I'll let you know if I fixed it.
Scott
Old Feb 2, 2003 | 02:36 AM
all stock's Avatar
check ur bolts if they are loose.
Old Feb 2, 2003 | 02:58 AM
iwantspoon's Avatar
Go to a exhaust shop sometimes a little tack weld can fix a rattling heat shield, or mayne even removing it. But it might cause your carpet to scorch a little under hard driving.
Old Feb 2, 2003 | 03:00 AM
iwantspoon's Avatar
Normal....the metal is expanding and contracting....annoying though
Old Feb 2, 2003 | 03:12 AM
PROJECThX's Avatar
Default LOOK Into This!!!
I had the same problem on my 98 civic. Some people told me to change the gaskets... that didnt work... others told me to check the heat shield... that wasnt it. I remembered my friends Si had the same problem so I asked him. He said check the exhaust resonator... took it in to an exhaust shop and they swapped in a new one *BAM* no more annoying rattling. I guess there was a small crack around the old resonator that caused it.
NOTE: The rattling from my exhaust came from the middle and could be heard when u are slowing down or at about 1-1.5k rpm.
OneCamIsEnough
Mar 10, 2006 09:04 PM
jayare05
11
Nov 23, 2004 08:18 PM
IntegraLs94Cam
Oct 1, 2004 05:43 AM
-iLLuZioN-B18C1
Oct 29, 2003 09:03 PM
bad93ex
Sep 28, 2002 02:19 PM
