4TH GEN VTEC, Power steering problem
guys i need help with power steering in 4th gen vtec.
i assembled whole engine bay
and filled power steering with SHELL AT FLUID.
it's not working, is it:
1. wrong fluid (i don't think so)
2. i connected something wrong
HELP!!!!!!!!!!! and sorry for bad english
and filled power steering with SHELL AT FLUID.it's not working, is it:
I'd just get a bunch of Honda powersteering fluid and keep running it through there.....
Get as much of the AT fluid out of there (dump the resevoir, take off the PS cooler in the front, etc) and try to get it out of there......then fill everything up with the honda stuff, go drive around for a couple days, then flush the sytem again and fill it back up......you should be fine after that I'd think.....
Brian
Brian
run the car and take the outlet hose off to the reservior. keep dumping in power steering fluid, honda or not. all of htem work.
you'll need a help from a friend to shut the car down.
but keep running the car and dump the fluid in a pan and your system will flush out.
