Need some slick sizing/gear ratio help to get me goin 1320 feet ;)
Old Feb 1, 2003 | 11:29 AM
Firedrake's Avatar
Default Need some slick sizing/gear ratio help to get me goin 1320 feet ;)
The car:
1996 Prelude VTEC/Stock Motor/9lbs boost/Custom setup with hondata
Probably making around 330+ SAE whp (made 311 on the dyno untuned and missing)
The tranny:
H22A1 tranny with Aasco flywheel, ACT clutch, and Quaife
1st: 3.31
2nd: 1.95
3rd: 1.36
4th: 1.07
5th: .87
Final: 4.27
I believe 4th gear tops out around 115 or so......is there a way I can calculate that? I need to pay more attention when I'm driving I guess.....
Anyways, I'd like to be able to do the 1/4 ending somewhere around redline in 4th so I don't need to shift to 5th......so the question is: Approximately what size slicks do I need to run to end the 1/4 at redline in 4th so I don't need to go into 5th? I'm assuming my mph will be somewhere around 113-115 or so (our 'teg making less power and weighing less did a 13.0 at 113 in phoenix, so I'm judging by that....)
Thanks!!!
Brian
Old Feb 1, 2003 | 07:04 PM
jlicrx's Avatar
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (Firedrake)
the formula for calculating this is: tire circumference=mph x gear x 1056 divided by rpm - for your car: tire = 115 x 4.27(1.07) x 1056 / rpm or simplified, 554847/rpm - the result will be the circumference of the tire which all of the manufacturers list in their specs - for instance; M&H 9.5/22/13 = 69"- M&H 9/22/13 or 8/22/13 = 70" - hope this helps.
Old Feb 1, 2003 | 08:43 PM
Furry
Guest
Posts: n/a
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (jlicrx)
i have a nice gear ratio calculating program made by quaife ill email you if you want... you put in your gear ratios and tire circumfrence and it spits out nice graphs and stuff
[Modified by Furry, 5:52 AM 2/2/2003]
Old Feb 2, 2003 | 12:20 AM
Firedrake's Avatar
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (Furry)
Thanks for the info guys! Yeah, I'd love to have that program, just shoot me an email
Brian
Old Feb 2, 2003 | 01:09 PM
lbz34's Avatar
Smallest widest slicks..
Like i said B
Sean
[Modified by lbz34, 3:10 PM 2/2/2003]
Old Feb 2, 2003 | 02:18 PM
Firedrake's Avatar
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (lbz34)
Bored Sean?
I need to find out if I can fit 13's over stock prelude brakes......
Brian
Old Feb 4, 2003 | 03:02 AM
Mista Bone's Avatar
D Tranny Guru
http://nonsense.netfirms.com/speed.html
Old Feb 4, 2003 | 10:54 AM
crazykid's Avatar
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (Mista Bone)
I know 14s jsut barley clear my brakes on a SR ( Si in the states) and the Si Vtec has even larger front brakes... so I doubt you cna put a 13" rim on a prelude...
Old Feb 4, 2003 | 05:42 PM
Furry
Guest
Posts: n/a
Default Re: Need some slick sizing/gear ratio help to get me goin 1320 feet ;) (crazykid)
if you have a SI or S you can use 14 inch wheels, if you have a vtec then you are stuck w/15's unless you downgrade the brakes
masterofphones
Oct 20, 2017 12:38 PM
carbon fiber coupe
May 29, 2015 04:33 PM
Si-ONARA
Nov 19, 2008 07:20 PM
MTR.18
Mar 27, 2005 08:11 AM
g2turbo
Mar 5, 2005 06:36 PM
