SALE!! - Motor rebuild parts -- KS Motorsports
Old Feb 1, 2003 | 08:45 AM
2K_TEG's Avatar
Default SALE!! - Motor rebuild parts -- KS Motorsports
ARP Rod Bolts
A large number of connecting rod manufacturers have chosen ARP® bolts as standard equipment. They’re proud to advertise their products as being equipped with ARP® rod bolts. And for good reason. The “weak link” in a connecting rod has always been the bolt, and racers know that nobody builds a better bolt than ARP®.
$45 Shipped
ARP Head Studs
It is for good reason that virtually every top professional engine builder relies on ARP® Pro Series head studs for their all-out competition powerplants. Simply stated, there’s not a better stud setup on the market today.
For openers, ARP® uses a premium grade 8740 alloy that is rated far superior to “aircraft” quality. Then, each stud is placed vertically in special racks and precisely heat-treated to 190,000 psi. This procedure ensures complete heat penetration and the results are far superior to those lesser quality studs from other manufacturers who just dump pieces in a basket and hope for the best.
Following heat-treat, each stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part. It’s important to note that lesser quality studs are not even centerless ground—the material is thread rolled in bar stock form (mostly before heat-treat, when the material is easier to machine). Because ARP® studs are manufactured to such exacting tolerances, you will note that gaskets and cylinder heads literally glide into position and are perfectly aligned—something that won’t happen with inferior quality head studs.
ARP® studs are thread rolled after heat-treat, which gives them about 1000% (that’s ten times) better fatigue strength than those studs that are threaded prior to heat-treat (a very common industry practice). It costs a lot more to do it this way, because it’s tough on tooling, but the results are well worth the extra effort.
$120 Shipped
ACL Engine Bearings
One of the largest ranges of automotive engine bearings in the world is produced by ACL Bearing Company, which is an approved supplier for original equipment bearings to all major vehicle manufacturers in Australia. This range covers all forms of internal combustion engines from small stationary petrol engines to large diesel applications.
Plain and flanged bearings are manufactured in a number of material options, including ACL's Duraglide F780 heavy duty, trimetal copper-lead material, to suit every performance requirement.
The company is dedicated to developing the most innovative and modern bearing production facilities to improve productivity, reduce delivery lead times and maintain the closest production tolerances.
$103 Shipped (includes main & rod bearings, thrust washers, plastigauge and clevite moly lube)
Eagle Rods
Forged H-Beam connecting rods.
$335 Shipped
JE Shelf Pistons
• Forged from Premium 2618 aluminum alloy
• Dome and dishes feature smooth flowing radii for
excellent flame travel.
• CNC Machined side relief with lower support band provides
optimal strength for extreme horsepower applications.
• CNC Diamond turned skirts with reduced cylinder contact
profiles provide less friction for increased horsepower
• Forced Pin Oilers for increased wrist pin lubrication
• Pin fitting, pin oilers and wire locks included
$495 Shipped (for JE Shelf Pistons: link)
Cometic's MLS (Multi-Layer Steel) Gaskets
These are constructed of two nitrile coated outer embossed spring steel layers with a steel inner layer that provides support to the gasket allowing multiple thicknesses. Cometic gaskets withstand the shearing forces created by aluminum heads on cast iron blocks. Once the gasket takes a torque set, there is no re-torquing required. Less clamping force is required allowing for reduced bore distortion.
Thickness: 0.025”, 0.030”, 0.040”, 0.054” $81 shipped
Thickness: 0.067”, 0.078” $126 shipped
Thickness: 0.098”, 0.120” $181 shipped
Cometic HP Style head gasket
These gaskets have an extra shim around the combustion area to help seal better for cars with turbo, nitrous or supercharger.
Thickness: 0.036”, 0.043”, 0.057” $101 shipped
Old Feb 1, 2003 | 08:58 AM
boosted3g's Avatar
Default Re: SALE!! - Motor rebuild parts -- KS Motorsports (2K_TEG)
Which headgasket do you recommend if you have an o-ringed block. 84mm gsr
Old Feb 1, 2003 | 09:22 AM
2K_TEG's Avatar
Default Re: SALE!! - Motor rebuild parts -- KS Motorsports (boosted3g)
GE recommends a stock HG for that.
Kyle
Old Feb 1, 2003 | 09:47 AM
AB16A2T's Avatar
Good prices.
Old Feb 3, 2003 | 09:55 AM
2K_TEG's Avatar
Default Re: SALE!! - Motor rebuild parts -- KS Motorsports (AresB16A2Turbo)
Adding Darton Sleeves.
$499 for B & D
$599 F, H & K
Old Feb 6, 2003 | 06:49 AM
2K_TEG's Avatar
bump
heretolearnandteach
Sep 28, 2008 06:51 AM
JDMHN8
Jul 26, 2005 06:23 PM
Civichatch2k
Dec 26, 2004 10:32 PM
ranta18
Sep 1, 2003 01:00 PM
