camber kit question??
Old Jan 31, 2003 | 10:51 PM
deez nuts's Avatar
Default camber kit question??
is it true you really only need a camber kit in the front for civics? been hearing that lately just wanted to make sure so i can save some money....by the 2.5 drop.
Old Jan 31, 2003 | 11:02 PM
Dr. Gonzo's Avatar
Default Re: camber kit question?? (ek4 fa sho)
Yea i guess it can be considered true. My progress camber kit came with some bolts and bushings for the rear. You just have to use as many washers as it takes to correct the negative camber or so that's what I get out of it.
-ben
Old Jan 31, 2003 | 11:27 PM
elwood's Avatar
It all depends on how negative your camber is. My car is pretty low and I only have these little metal shim things. There like washers almost. It dosent depend on the car, it depends on the camber.
[Modified by d15dude, 8:30 AM 2/1/2003]
Old Feb 1, 2003 | 01:53 AM
deez nuts's Avatar
Default Re: camber kit question?? (d15dude)
koo koo i'm working on my sus. just want to ride good and handle good.and save some money on tires....
Old Feb 1, 2003 | 01:57 AM
SoulSurfer's Avatar
When I dropped my Civic without a camber kit the front and rear both wore but the front wore about 4 times quicker than the rear.
Old Feb 1, 2003 | 06:35 AM
couter.net's Avatar
Default Re: camber kit question?? (LSDelSol)
Yah just depeneds on the drop.
Guy before me totally messed up my camber.
I got a Skunk2 camberkit for the front. 2washers(4 total) in the back I have ALMOST perfect camber in the back.
Old Feb 1, 2003 | 07:38 AM
Noe Kozz's Avatar
Default Re: camber kit question?? (couter)
That's a nice drop you have there d15dude.
Old Feb 1, 2003 | 09:46 AM
elwood's Avatar
Default Re: camber kit question?? (Noe Kozz)
Thanks, last time I posted it I just got flamed. I bought a front OEM lip but I
dont have any picture on my computer yet.
Old Feb 1, 2003 | 10:13 AM
deez nuts's Avatar
so you only need washers in the rear???
Old Feb 2, 2003 | 03:25 PM
elwood's Avatar
It depends on how negative your camber is,
but most people dont need to buy a rear kit.
It can usually be corrected with "shims" or washers.
Old Feb 2, 2003 | 04:05 PM
93civEJ1's Avatar
Default Re: camber kit question?? (benji)
i only have camber kit on the front and it seems to be doing good...i have the ingalls...no kit in the back, but the reason fronts wear out so quick is because they do all the action....turning and accelleration.
Old Feb 2, 2003 | 07:27 PM
deez nuts's Avatar
Default Re: camber kit question?? (93civEJ1)
very true!!!!!! i lowered mines 2.5 wasn' happy with the drop want to g lower.
Old Feb 3, 2003 | 08:46 AM
Patrick's Avatar
Ive heard stuff about the SRR kit being good and cheap but Im not sure where to get it, maybe someone could let me know?
Old Feb 3, 2003 | 08:47 AM
cccya's Avatar
Default Re: camber kit question?? (gsr_vx_hatch)
skunk2
Old Feb 3, 2003 | 11:16 AM
nd8ch's Avatar
Default Re: camber kit question?? (cccya)
camber corrections are great is you want to conserve tires. but if you have some cambering, it will improve your handling if tuned correctly. Its just a tradeoff between good handling or good tirewear. just a tip
shibbywhitedude
Sep 6, 2007 03:04 PM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
blk94gsr
Feb 11, 2006 07:23 PM
fafsa
Apr 6, 2005 03:40 PM
es_squared
Apr 3, 2004 02:04 AM
