piston upgrade
Old Jan 31, 2003 | 10:20 PM
kenepo's Avatar
Default piston upgrade
I want to know wich pistons I can use on a zc sohc engine?
Old Feb 1, 2003 | 04:53 AM
keithv's Avatar
Default Re: piston upgrade (kenepo)
just honda ones? aftermarket ones? both?
we need some more info here.
Old Feb 4, 2003 | 06:53 AM
WickidSi's Avatar
On my crx si d16a6, i put in 88-89 d16a1 teg pistons. gets you about 11 to 1 compression. Make sure to have block bored and get oversized pistons. It allows new rings to bond with cylinder walls better. I stuck with stock bore pistons and now i burn oil.
Old Feb 4, 2003 | 02:09 PM
zCivic's Avatar
Any D-Series would work. As for compression ratios that I dunno about seriously. You have to consider what rods your using. Is a SOHC rod length the same a say a SI?? If so go by what they sell for a D16A6 and what there compression ratio is. Z6's have a little higher C/R with the same length rods, can try those or DX's pistons on SI rods and raise it some more based on DX's having 9.2 c/r with .21" shorter rod length. This is based from a chiltons manual which cover 88-95 it has rod length and c/r based on honda specs (hehehehe)
Old Feb 4, 2003 | 02:11 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
do a archived search for - piston project
ElswickB22
Aug 6, 2013 08:44 PM
bigbpatel
Nov 8, 2012 01:56 PM
Dark_Teg
Sep 21, 2006 08:22 AM
89civichatchback
May 2, 2003 12:43 PM
