Small CV boot leak
Old Jan 31, 2003 | 09:50 PM
Que_Lude's Avatar
Default Small CV boot leak
Hey guys, what do you do when you get a leak with the CV boot? It's a 94Vtec and I noticed a small ammount of grease spray from both boots. Thanks in advance for the help/advice...
Old Jan 31, 2003 | 10:47 PM
prelude1897's Avatar
Default Re: Small CV boot leak (Que_Lude)
Just buy a new one and replace it. They aren't too hard to replace, or just take your axle to a shop and have them replace it for you
Old Feb 1, 2003 | 06:07 AM
AndyD's Avatar
Default Re: Small CV boot leak (prelude1897)
https://honda-tech.com/zerothread?id=398472
Old Feb 1, 2003 | 06:09 AM
AndyD's Avatar
I have heard mixed reviews ab out how easy/hard it is to install axles. Some say it is prety easy while others say it is tricky/time consuming.
From what I understand...if you have oem axles...get the boots changed SOON. I heard that aftermarket ones are not that great.
Mine are leaking a little but I only need them cleaned up so it passes inspection. I plan on getting an H22 soon anyways.
Old Feb 1, 2003 | 11:33 AM
Que_Lude's Avatar
Default Re: Small CV boot leak (AndyD)
AndyD, thanks for the info. I can't believe what a hassle it is to fix this type of problem. Although it's a small ammount of spray, I like to keep the lude running in good condition. I don't know if it's worth it to take it to a shop to get it repaired. I don't have any boot cracks and both axles are in good condition.
Old Feb 1, 2003 | 04:34 PM
AndyD's Avatar
Yup, that is my same dilemna. But the thing is if the grease leaks out more..this will accelerate wear on the axles.
Old Feb 1, 2003 | 10:31 PM
Cottonwoodz's Avatar
The Si axles, are the same as the VTEC axles. And if your planning on doing a JDM h22a swap, you prob wont be able to use the axles that come with the swap. Usually you end up with NON ABS axles.
[Modified by Cottonwoodz, 1:32 AM 2/2/2003]
g0tgot
Jun 29, 2007 04:52 AM
Broken Devil
Oct 27, 2004 11:27 AM
lahight
Sep 3, 2003 01:26 AM
AndyD
Jan 28, 2003 04:20 PM
