painting side skirts
Old Jan 31, 2003 | 09:27 PM
1Tym's Avatar
Default painting side skirts
has anyone with an integra tried painting the stock black sideskirts...preferably at a prefessional shop?? how was it or how much do u think it would cost?
Old Jan 31, 2003 | 11:02 PM
elwood's Avatar
Default Re: painting side skirts (Integra199)
It shouldent be very expencive. Try the search and if you dont find anything call your local body shop and ask them for a quote or estimate. IMO I dont think you should do it. Its your car though. Good luck with it.
Old Oct 30, 2003 | 06:14 PM
1Tym's Avatar
do you guys think $140 is a good price?
Old Oct 30, 2003 | 06:55 PM
BoostedSOHC's Avatar
Default Re: painting side skirts (1Tym)
70 apiece sounds about right, 50$ would be a dman good deal
Old Oct 30, 2003 | 07:42 PM
streetlights's Avatar
Default Re: painting side skirts (BoostedSOHC)
i did it myself and it was a perfect match...three cans of duplicolor milano red paint from kragen...i highly recommend it...if it woulda looked shitty i woulda just painted them black again but it came out really well
Old Oct 30, 2003 | 10:33 PM
DownBoyDown's Avatar
$140 seems fair, just make sure that they use adhesion promoter or else the paint will chip off over time. I you wanted you could probably do it yourself. Just scuff the entire sideskirts with a green Scotch Bright pad, then wash the piece and rub down the sideskirt with some kind of degreaser. Next spay the Adhesion Promoter, then spray your primer. After the primer is dry then come back and wet sand the entire sideskirt. Again use the degreaser to clean off the piece, then spray a coat of Adhesion Promoter, and then finally a couple layers of paint. I did this with a gun but you could probably try using the duplicolor paint, just test it out first to make sure that it matches your origional paint. You can get Adhesion Promoter at any Automotive Paint supply store.
Old Oct 30, 2003 | 10:38 PM
alfaaay's Avatar
Default Re: (DownBoyDown)
~$25 dollar DIY after a body shop told me they wouldn't do it because it didn't appear as if it was "meant to be painted:"
Old Oct 31, 2003 | 10:31 AM
watacivic's Avatar
Default Re: (alfaaay)
your DIY sideskirts looks just as good as a shop would have done maybe better...nice work
Old Oct 31, 2003 | 10:42 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">~$25 dollar DIY after a body shop told me they wouldn't do it because it didn't appear as if it was "meant to be painted:"
Now that's a great job right there, that looks professional. But to be honest, most of the do it yourself jobs that I've seen don't look so great, they start fading and don't match over time.
Old Oct 31, 2003 | 10:55 AM
Default Re: (rodrez)
at first the paint wont match (it didnt for my milano red) but after you keep coating it, eventually itll match
Old Oct 31, 2003 | 01:14 PM
alfaaay's Avatar
Default Re: (streetlights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">at first the paint wont match (it didnt for my milano red) but after you keep coating it, eventually itll match</TD></TR></TABLE>
w0rd. You've got to apply lots of coats in an even fashion. If they aren't thick, the paint will look lighter usually. If they aren't even, you'll be able to tell once it dries.
haunda
Paint and Body
Sep 22, 2010 11:02 PM
Thrillhouse
May 22, 2004 11:20 PM
integraautox
Jul 12, 2003 11:33 AM
2K_TEG
Oct 2, 2001 02:20 PM
The LS Avenger
May 3, 2001 05:09 PM
