Apexi VAFC
Old Jan 31, 2003 | 04:23 PM
gary201147's Avatar
Default Apexi VAFC
Does anybody with a VAFC hook it up by NOT splicing and soldering the wires into the ECU? I want a harness that I can use so I dont have this wirey mess on my ECU...is this not recommended? Thanks in advance.
Old Jan 31, 2003 | 04:25 PM
jonas's Avatar
Default Re: Apexi VAFC (gary201147)
i believe Kenji can make you one.
or i think Leo from JDMspecperformance sells a harness like that..
click on my sig for info on either of them.
[Modified by jonas, 5:26 PM 1/31/2003]
Old Jan 31, 2003 | 04:28 PM
Hooch'n's Avatar
Default Re: Apexi VAFC (jonas)
make sure if you don't use the harness you use a s. iron when putting wires together. Makes it less of a mess and get a good signal becuase wires don't come un-done.
Old Jan 31, 2003 | 11:16 PM
typeR00-0005's Avatar
you have to splice in to the ecu. no other option
Old Feb 1, 2003 | 01:09 AM
jonas's Avatar
Default Re: Apexi VAFC (typeR00-0005)
incorrect.
Old Feb 1, 2003 | 01:33 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
aren't the harnesses a pretty penny though? like $100+?
Old Feb 1, 2003 | 01:45 AM
Art Vandeleigh's Avatar
your an idiot. if you dont know the answer dont bother posting anything please.
you can use a custom made "jumper" made by kenji (which i have) or you can get an off the shelf one. i believe that leo does sell one of the off the shlef ones that are specifically made for the vafc...but dont quote me on that.
in either case all you will have to do is solder or crimp (not recommended) the vafc wires to the "jumper" and plug the jumper to your ecu. simple as pie
there are a few more options but the ones i just mentioned above i think are the best and least complicated.HTH
Old Feb 1, 2003 | 08:47 AM
Tweakmeister's Avatar
Default Re: Apexi VAFC (Art Vandeleigh)
This is the Field's Harness. It took some reading to get the connections right.
Old Feb 1, 2003 | 12:50 PM
gary201147's Avatar
Default Re: Apexi VAFC (Tweakmeister)
So the Fields harness DOES work with the VAFC, but just not directly right? By that I mean that all the wires dont translate into the same wires for VAFC as Fields. Yeah?
Old Feb 1, 2003 | 07:10 PM
most of the wires are the same...
once I had the wiring diagram for the Car ECU, it was easy to just trace it to the corresponding Field's Unit placement. Took like 30 minutes to get it soldered and working the first time.
Old Feb 1, 2003 | 07:53 PM
neo1z's Avatar
I would just splice em and solder em...doing it right will take you no longer than an hour or so. Getting that experience is good for ya too It is how i learned to solder
Old Feb 1, 2003 | 08:15 PM
Dropspeed's Avatar
You mentioned soldering but I see scotchlocks (sp?) I would recommend removing those.
Old Feb 1, 2003 | 08:59 PM
gary201147's Avatar
Default Re: Apexi VAFC (neo1z)
I am not denying that its good to solder but I just dont want to solder into my own ecu. I would rather solder into somethign that i could remove later and have my ecu be as good as new. But yeah...i would not crimp them anyways, when i get a harness I WILL solder it.
Old Feb 2, 2003 | 02:41 PM
Default Re: Apexi VAFC (Dropspeed)
Those are for tapping into the ground wires. At the time they seemed like a great option. Are you concerned with the signal quality of the connection?
edit\\\
You know what, I'll just solder the wires into the locks.
[Modified by Tweakmeister, 6:48 PM 2/2/2003]
Old Feb 2, 2003 | 03:15 PM
MrJasey's Avatar
y not solder...u can unsolder later and it will still be "good as new"
just do a good job and use shrink wrap to make it look nice...definitely cheaper than buying a harness and as long as u do a good job it wont be shitty
Old Feb 2, 2003 | 05:29 PM
Scotty B's Avatar
Thier shouldnt be too much problem with going directly to the ecu.......if you take your time and do it neatly it wont be a wirey mess, and their wont be a need to waste money on a harness. If you are concerned about doing it yourself , it is really easy just follow the diagram. Besides if you want to go to obd-1 later(if you arent already) that will be another harness. i dont know though........just a penny for your thought!
[Modified by nasi, 2:36 AM 2/3/2003]
Old Feb 2, 2003 | 05:33 PM
Default Re: Apexi VAFC (nasi)
I wanted to be able to remove the assembly easily.
Old Feb 2, 2003 | 06:04 PM
TypeR 01 886's Avatar
Whats the best vtec point for performance on a stock r? I would like to get a VAFC but I dont think I have enough mods to pay its justice.
Old Feb 2, 2003 | 07:12 PM
Default Re: Apexi VAFC (TypeR 01 886)
then wait to buy one.
who knows, maybe you'll strike gold and be able to go the Hondata route
Old Feb 2, 2003 | 07:44 PM
Dave-ROR's Avatar
want a harness? email kenji ( kenji211@tampabay.rr.com )
otherwise cut/tap and solder. if you car is under warranty it'll be obvious that a VAFC was installed however (if you have an electrical issue, etc and the dealership checks) unless you use a harness.
hondacribb
Mar 16, 2007 03:28 PM
guymosiris
Apr 7, 2005 02:52 AM
fittyonefittyx73
Dec 27, 2003 12:35 PM
ArchAngel Sabastian
Dec 7, 2001 06:05 PM
Dropspeed
Oct 1, 2001 07:29 AM
