Piston color/appearance
Old Jan 31, 2003 | 02:33 PM
SpoonEK2's Avatar
Default Piston color/appearance
I just pulled my spark plugs out to check them (stock plugs, 62,000miles) and will be replacing them with NGK BKR6E-11's. Anyways, I looked down the hole to see what the pistons looked like and they're kind of crusty/black looking. What should they look like after 62,000 miles? It's a B16A2. I've changed the oil every 3-3.5k miles and on a recent dyno pull, made 141hp to the wheels. I'm in the process of finishing up the 60k maintenance.
Post pictures of healthy pistons...
Old Jan 31, 2003 | 03:06 PM
1SlowB16EF's Avatar
Default Re: Piston color/appearance (SpoonEK2)
its most likely just carbon build up ... could help and could hurt... it raises compression ... but it also makes hott spots which can cause detonation ... i would reccomend a top flush!
Old Jan 31, 2003 | 04:08 PM
SpoonEK2's Avatar
Default Re: Piston color/appearance (1SlowB16EF)
i would have thought all the carbon would have been blown out the way i drive...
how would you do a top flush?
Old Jan 31, 2003 | 04:58 PM
Tweakmeister's Avatar
I think you're probably fine
Old Jan 31, 2003 | 09:55 PM
delslow94's Avatar
Default Re: Piston color/appearance (Tweakmeister)
u should be ok..run some good octane booster or fuel system cleaner...enough to foul ur plugs then once the tank is gone replace the plugs with new ones. it should clean them up pretty good.
Old Jan 31, 2003 | 11:26 PM
SpoonEK2's Avatar
Default Re: Piston color/appearance (red240ne)
sea foam?
Old Jan 31, 2003 | 11:43 PM
dilligaph's Avatar
yep its a multipurpose detergent... pick it up at napa. its says auto/marine on it and has a red label. works wonders.
read this for more info:
http://www.nissaninfiniticlub.net/vb...hlight=seafoam
[Modified by dilligaph, 8:51 AM 2/1/2003]
KStuned
13
Jun 20, 2018 06:11 PM
motegicivic
Mar 19, 2012 11:59 AM
the_dxB16
May 25, 2011 08:34 PM
shortlid
Mar 11, 2011 10:42 AM
.Ry
Oct 24, 2005 09:20 PM
