99 gsr brakes on crx
I tried a search but couldnt come up with anything.... Can get some 99 gsr complete brake/suspension for a good deal. Just wondering what I would need to do. Any info would be appreciated.
Yager-
Yager-
I think you won't have a problem with the trailing arms. You might need new e-brake cables. Also a master cylinder and proportioning valve aren't necessarily needed but are said to help pedal response. I would also use you stock lower control arms or lower control arms off an CRX SI if your LCAs don't have holes for the swaybar endlinks to mount to. I would also try to get the master cylinder and proportioning valve from a CRX SI to ensure compatibility. Also get the e-brake cables from the CRX si too.
I have never done the swap but it is very similar to the other models. The trailing arms are all the same. The LCAs are different. I don't think it will have any affect on suspension geometry.
Hope this helps.
Hope this helps.
gsrhatch530
Aug 16, 2005 12:35 PM
ironchef25
Jul 11, 2004 12:37 PM
