window alignment
Old Jan 31, 2003 | 11:48 AM
SlammedHatch90's Avatar
Default window alignment
my driver side window will roll down fine but when you try to roll it up it gets all wamperjawed and what not. does anyone know how to align a window? i really dont feel like pay 145$ to have someone do it. i wanna try myself first. thanks in adavnce.
Old Jan 31, 2003 | 12:05 PM
martini's Avatar
Default Re: window alignment ( SlammedHatch90)
First I would try rolling the window down, and spraying some silicone lubricant down the rubber "rails" that guide the front and back edges of the window...
Old Jan 31, 2003 | 12:30 PM
BigBank420's Avatar
Default Re: window alignment (martini)
You more then likely have a bent or worn window regulator. I to had to replace this item last summer. It really wasn't that hard but it does require removing the door panel and the glass and then removing all 10mm bolts and removing the regulator through a small whole in the door. If I remember correctly the part was about $65-70 bucks from the dealership. Again Im not their to see the problem but this does sound like what your running into. Hope this helps and good luck!
Andy
Old Jan 31, 2003 | 03:49 PM
.ShawnD.'s Avatar
Default Re: window alignment (BigBank420)
i had this problem and went through 3 window regulators!!!
try this first .. take your door pannel and there should be either 2-3 10mm bolts(looking at the door from inside the car) its right of the speaker you cant miss them they are goldish colored loosen them up enought to slide them over to the right.. that should work ..
if not look and see if your window reg is bent.. its hard to tell but look in the middle of the X.. if its confusing PM me ill try to explane better
[Modified by .:s h a w n D:., 12:50 AM 2/1/2003]
CivicRaping
Nov 15, 2020 12:47 PM
bopbop93030
Nov 20, 2008 09:03 AM
deerman2701
Nov 27, 2007 05:59 AM
4Dinsaneb16
Mar 20, 2007 01:30 PM
.jacob
11
Mar 3, 2003 05:25 AM
