Idle adjustment screw, screwing itself in?!?!?!?
Old Jan 31, 2003 | 06:48 AM
slow02ss camaro's Avatar
Default Idle adjustment screw, screwing itself in?!?!?!?
I think I've figured out my cel problem, with the fuel supply(#43), for some reason my idle screw on the intake manifold is screwing itself in all the way and so my idle is soo low that the fuel pressure drops b/c the car is about to cut out at every single stop. I then unscrew the adjustment like 5 compete revolutions out and reset the ecu but in a week or so the screw is back all the way in and my idle sucks and I start throwing the code. So why is my idle screw screwing itself in?!?!?!?!
Old Jan 31, 2003 | 09:16 AM
JTCdudeman's Avatar
Master H Technician
Default Re: Idle adjustment screw, screwing itself in?!?!?!? (slow94accord)
vibration... You can get some thread lock stuff that will hold it in place for like $3 or so... GOOD LUCK
Old Jan 31, 2003 | 09:41 AM
papa_smurf's Avatar
Default Re: Idle adjustment screw, screwing itself in?!?!?!? (JTCdudeman)
doesn't that screw have a small o-ring around it? thats what is supposed to stop it from moving, go to honda or autozone and get an o-ring. = non-ghetto fix
Old Jan 31, 2003 | 12:14 PM
LudeyKrus's Avatar
Default Re: Idle adjustment screw, screwing itself in?!?!?!? (papa_smurf)
Where is the idle-adjustment screw on an H23? I may have a problem that that could fix
Old Jan 31, 2003 | 12:40 PM
I think you are right, I'm gonna get a new o-ring and see what happens. I was just scared to unscrew it all the way out...wasn't sure if it held anything inside together but i found it doesn't so I'm gonna replace the o-ring.
Old Jan 31, 2003 | 01:38 PM
Cottonwoodz's Avatar
(You can take the screw right out)When you put the new O-ring on, clean the Idel screw with carb cleaner to get the carbon buildup off it.
Old Jan 31, 2003 | 09:00 PM
papa_smurf's Avatar
Default Re: Idle adjustment screw, screwing itself in?!?!?!? (Cottonwoodz)
anything i can do to help
b20eg9daddy
Oct 25, 2008 12:37 PM
MMMm Waffles
Jun 28, 2008 02:58 PM
shadycrx
Feb 22, 2006 03:08 PM
eric416
Aug 5, 2005 09:50 AM
Dr. Gonzo
Jan 12, 2004 03:53 PM
