kick me i'm a n00b and need advice from h-t guru's
Old Jan 31, 2003 | 04:52 AM
Drews Bitch's Avatar
Default kick me i'm a n00b and need advice from h-t guru's
ok fellow h-t members.. to put it lightly uncle sam has a good pay-out for me this year. bucause i'm not doing a swap just yet i want to do some suspension..
i never auto-x or drag but i do want a nice set-up under $1000.
should i go koni yellows w/ comptech springs or tein ss ???
what do you think and why? if you never used either or had expirence with either you need not apply...
thanks
j
these will be on a 99 hx coupe
my
Old Jan 31, 2003 | 04:55 AM
ZappasOne's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (shepworldwide)
I have Koni Yellows on my Civic w/ comptech swaybars and my car handles like a champ, but I would say go with the Koni's,they are a really good spring and I would recommend them to anyone...
and I would go with Teins as well...
Old Jan 31, 2003 | 05:08 AM
ill phil's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (ZappasOne)
If you're going to use Koni Yellows, why not look into some Ground Control coilovers? Many people praise this set-up a lot and you have the ability to change out the spring rates now or in the future. That and couple of good sway bars and you're in business.
Old Jan 31, 2003 | 05:16 AM
Default Re: kick me i'm a n00b and need advice from h-t guru's (ill phil)
thanks for the advice guys..if it's not to much could you put some $$ figures on these set-up's also..
i also have'nt really heard anything good about gc's. price of being a newb i guess
Old Jan 31, 2003 | 05:55 AM
ill phil's Avatar
Yeah if you search around you will definitely hear praise of GC's. They use Eibach ERS springs which many companies use as replacements for different spring rates.
Lets say you pick up basic Koni's - $500-$550
Ground Controls (even with custom rates now, at least go for Integra rates)- $325-340
You're still coming in under you $1000 budget and have a couple hundred to use on other forms of chassis stiffening.
Old Jan 31, 2003 | 06:03 AM
you guys need to remember that i'm still an just a wookie at this stuff. so when spring rates and all of that become involved i'm a little lost. i've also read about hondas sagging on the drivers side and this is something i most deff want to avoid..
which is why i'm leaning more towards coilovers.
Old Jan 31, 2003 | 08:29 AM
.hugo's Avatar
if you just want a nice suspension set up. you may want to look into some gc's and kyb agx's. It's cheap and gives you great ride quality. I'm running that set up right now and love it.
GC's are about 300, but you can probably find them cheaper if you search around. And You should be able to find KYB agx's for around 320-340. That leaves you with quite a bit left over, maybe for some sway bars or strut bars.
Old Jan 31, 2003 | 08:38 AM
SoulSurfer's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (starang)
$587 shipped will get you Ground Controls with Tokico blues. I had those on my hatch and the ride was nice. Don't forget to get a camber kit though. Very important.
Old Jan 31, 2003 | 08:41 AM
BackSideSA's Avatar
I am using Tokico Blues with Gold Line springs....rides like stock.
The set up cost me 175 for everything. Tokico's were used for 2 months and the springs were new out the box with lifetime warranty. Normally that set up would run about 500.
Old Jan 31, 2003 | 08:47 AM
93SSPHatch's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (HybridHackBatch)
I as well went with Tokico blues and some progress springs and I love it. I also made sure to add a camber kit all around and a nice 22mm lower roll bar to the rear. Good luck.
A little OT, but you should try and not have a tax return, that way good old uncle doesn't get to hold onto your money all year round. Anyways, good luck with the suspension upgrades.
Ryan
Old Jan 31, 2003 | 09:23 AM
Default Re: kick me i'm a n00b and need advice from h-t guru's (93SSPHatch)
Ryan
thanks for the info..but i tried the other way and ended up paying uncle sam
anyways i'm reciving a huge return and only want to take about a g to do my car cuz having a garage to work in is more important to me
not to offend anyone i'm not looking for the cheapest set-up.. just comparing what my original topic was.. and maybe gc's like someone else has said if i find enough praise..
Old Jan 31, 2003 | 09:30 AM
all stock's Avatar
cuz now u can get those 23mm sways and some decent struts and a camber kit [get the front, u can DIY the rear]
Old Jan 31, 2003 | 09:38 AM
GsR HtCh's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (all stock)
sorry to jack the thread but will tein ss's work better than the above mentioned combo's? im thinking of getting them pretty soon. ive heard alot of good things about them.
Old Jan 31, 2003 | 10:34 AM
phillycx's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (LSDelSol)
Where did you get this deal from? Please, let me know. Thanks.
Old Jan 31, 2003 | 10:41 AM
acydphryck's Avatar
thanks
j
my
try Teins since they have been proven under racing conditions in the JGTC. i would go with the Tein HA setup...but you would have to replace your lower control arms with the ITR ones from the dealer...they cost like $100/pair...brand new. check in the classifieds for the LCAs...you should be able to get them for less than that....
Old Jan 31, 2003 | 10:45 AM
Default Re: kick me i'm a n00b and need advice from h-t guru's (acydphryck)
whats the diffrence between the HA's and the SS's ?
thanks again guys for all your help
Old Jan 31, 2003 | 10:47 AM
GsR HtCh's Avatar
i wanna know 2.
Old Jan 31, 2003 | 10:52 AM
-Whitey-'s Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (98civichtchback)
tein ss are great coilovers i recommend them
the ss is the replacement for the HA i think they are the same except the ss dosnt have the keeper spring and the HA does..but that only matters on the ss if you have them all the way down..i have mine at 1.5 up from the bottom in the front and 2 in the back and ill never need a keeper spring
Old Jan 31, 2003 | 10:55 AM
Default Re: kick me i'm a n00b and need advice from h-t guru's (FF-Panda)
what is the little box thing with the wires above the coilovers?
edit: i just realized thats a ps2 with a sticker on it
[Modified by shepworldwide, 2:57 PM 1/31/2003]
Old Jan 31, 2003 | 11:22 AM
xJ.SLOTHx's Avatar
hahahahaha, its a PS2. brighten up your monitor some....lol
Old Jan 31, 2003 | 01:41 PM
silverEH2's Avatar
thats the dope shitz
Old Jan 31, 2003 | 02:06 PM
eccentric.ek's Avatar
Default Re: kick me i'm a n00b and need advice from h-t guru's (silverEH2)
save and buy teins!!! u cant go wrong!
Old Jan 31, 2003 | 09:05 PM
Default Re: kick me i'm a n00b and need advice from h-t guru's (redUSDMhb)
bump for the night
Old Jan 31, 2003 | 09:15 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I would personally go with the Neuspeed Konis which are shorter bodied than stock which is a very nice thing to have where shock travel is concerned. IIRC, there is a groupbuy going on with those right now for around $500. For the springs, I would pick Ground Control sleeves/perches, and Eibach ERS springs... the spring rate is personal preference and it would suit you to do some research and figure out a good compromise for your driving style. Read the Autocross/Road Racing Forum and the ITR forum for a lot of talk about spring rate. I'm unsure of what GC kits cost w/ the "Koni adaptor kit" and custom rates, but it will be under $400.
$900 which is roughly the same cost as the Tein SS whose sleeves I really don't like compared to GC and they're stock length.
That's what I would do if I had to do it all over again for under $1000.
xd69
Suspension & Brakes
24
Mar 9, 2011 07:26 PM
HighRevn
Jun 14, 2009 05:23 PM
sh0rt1e67
Mar 4, 2009 04:50 AM
ej8_dave
14
Jan 14, 2008 11:31 AM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
