Need help car problem ????
Old Jan 31, 2003 | 04:12 AM
AcCoRdStReEtRaCeR's Avatar
Default Need help car problem ????
hey i have 91 accord (f22a1) . I put in a 92 motor (f22a6) i got everything connected. when i got it started the idle stayes at 2300k then startes to jump around . if you give it alil gas or when it startes to warm up. the idle startes to jump . what sensors or what can cuase this .. please help thank you so much ????
Old Jan 31, 2003 | 04:41 AM
Stew Pidasso's Avatar
Default Re: Need help car problem ???? (AcCoRdStReEtRaCeR)
Could be Fast idle valve, Idle air control, temperature sensor, or MAP sensor. Are you getting any CEL codes.
<U> And please read the forum guidelines at the top of the page about thread titles like this one. </U>
Old Jan 31, 2003 | 05:18 AM
Default Re: Need help car problem ???? (Stew Pidasso)
it was a code 7 .
Old Jan 31, 2003 | 05:32 AM
7 TP Sensor (Throttle Position)
defective circuit or unplugged / defective sensor
Check to make sure your throttle position sensor is plugged in all the way. If it is bad, I believe that one from any f series or h series would work. Go to a junk yard.
Old Jan 31, 2003 | 09:23 PM
how do you change the TP sensor . there are no srews on it or bolts it is like a clip ???
snowboarderbrt
17
Sep 4, 2014 01:42 PM
kootari
Feb 10, 2007 04:07 PM
CA6VTEC
Sep 14, 2004 05:57 PM
