LSVTEC please read and reply thank you
hello i am planning on doing lsvtec with a b18b blocka nd a gsr head..... want to hear form people with this experience.... how the motor runs power.... and cost thank you
Runs great.. lots of torque.. I usually do b20s swaps though since the blocks are so new. Make sure you buy new head and intake manifold gaskets though.. some ppl don't and they have bad oil/coolant leaks.
all the answers to your ls/vtec questions are here: http://www.c-speedracing.com
just did an ls/vtec setup on my friends 98 civic dx. we added all new parts, nothing was reused. we have high compression wiseco pistons, crower cams, etc. we have a lot done. it runs very strong. it needs to be tuned but it runs good so far. although we are using a b18c5 head and b18a block. if you do yours correctly you should be happy.
Most people go with the b16 head since it can generally be had for fewer dead presidents and performance is roughly equal. If you're not planning to swap out the tranny to a GSR or S4C tranny then you'll likely not be nearly as happy with your frankenmotor. As far as cost goes, I just picked up an entire b16a1 engine for $200 from a fellow cleaning out his garage, and I've seen several adds for $200ish b18a/bs. Naturally any such engines should be completely gone over(rebuilt) prior to resurection.
I have a b16 head on my b18b block and have 90,000 miles on my car and got the swap done around 75,000 and have not had any problems since i got it done(except a leak in the fuel rail, but that was the shops fault, i have my ls tranny so its kinda slow! but its runs so good and sounds great. vtec kicks at 4800.
I still have my ls ecu and my vtec is turned on by a MSD RPM activation switch at 4800 and my redline is my stock 7200
is your bottom end built at all, or using stock LS internals? looking at ur sig....never seen numbers that low before, so i am just wondering
Make sure you align the dowel pin for VTEC oil pres. exact, or it can rip the head gasket causing it to leak. It wouldnt be a bad idea to run VTEC oil pump and water pump either. For everything to run optimally, you might as well just bought a GSR motor in the first place. Actually, Ive been told by very reliable sources that you can make just as much if not more power/torque with a built LS motor. VTEC just gives you better driveability in traffic and better low end response, but then again we're talking 4 bangers here so there isn't much low end power to speak of anyway...
yeah man i actually have that setup in my car..ls block gsr head...i love it, havent had a problem yet...and its even better now that i switched trannys to the b16..i would recommend it cause i love my setup
[Modified by g2teg 2nr, 6:37 PM 3/7/2003]
The car that I bought already has a LS/Vtec swap. I like it and it runs well. However I prefer an LS Turbo. Do to the feel of the acceleration. Then again the LS/Vtec has a better driveability if you are in to Autocross.
