How to hardwire?
Old Jan 30, 2003 | 08:40 PM
CounselorBob's Avatar
Default How to hardwire?
I wanna hard wire two 9" Street Glow Neon Lights into my 97 Civic EX ... how do I do that? Is it even possible?
Old Jan 30, 2003 | 08:42 PM
Starrman85's Avatar
Default Re: How to hardwire? (CounselorBob)
if ur talkin about neon lights that have the cig plug, cut that off, one wire will go to a 12v power source(battery) and the other will be grounded. you'll also wanna put a switch on that, or else they will always be on. are these going on the inside or outside of the car?
Old Jan 30, 2003 | 09:12 PM
Default Re: How to hardwire? (STARRMAN85)
goin on the inside
Old Jan 30, 2003 | 09:32 PM
sackdz's Avatar
I would put them on an accessory feed so they can only come on when the key is turned to acc/on. You can find this wire using a voltmeter and it will turn to 12V once the key is turned to acc or on. I would splice it out of the radio harness or directly into the fuseblock with a female crimp connector. You can unplug the radio and stick the probe in the end or the connector to find the correct wire, then splice it.
[e] And of course, run a switch off either +12V or the ground side.
[Modified by sackdz, 1:32 AM 1/31/2003]
crazyhouse2011
Nov 20, 2015 04:27 AM
BrayzieEF9
14
Jan 5, 2010 06:47 AM
Evan125
Dec 3, 2009 10:41 AM
chrisir19
Jul 21, 2003 09:14 AM
Want2race
Jul 13, 2003 11:09 AM
