Apex'i turbo timer, already did a search
I have a 90 honda prelude, as far as the ignition wires from the timer go, it says one wire is for ignition 1 and the other is for ignition 2. From the information I found on my car I only have 1 ignition wire. What do I do? Thanks guys.
i'm pretty sure when i hooked my apex'i turbo timer i just used ign 1 and the constant. the second one i didn't hook up to anything. that **** works just fine too.
i just stumbled across this thread while looking for something. you have to hook up the second wire to the blower... if not, your radiator fan will not run. I didnt hook mine up, and had the car running for a while., came back and the engine was over heating. I did the same as you guys, it works just fine without the radiator hooked up...i guess it doesnt matter if you dont idle long...but just incase, i suggest you hook it up
Thanks for the tip. My fans stoped working a long time ago for some unknown reason so I just wired them to a fuse so they are always on when I turn the key on. Thanks for the advice though.
if you care to know: i think if you always have your fan running, it will take a little power away from your engine, probably not enough to notice, but you might run into premature wear too. just giving you a heads up
Yea, I know, but they just stoped working after my engine swap and I could not figure out why. So I just hard wired em. Thanks though.
_Endless_
Jan 5, 2003 09:50 PM
