B16a into a 90 crx questions
Just bought a 90 crx..I would like to do a swap what all will i need? WHat will need to be changed ? I am a mechanic so I guess thats a plus. Also what are some good sites to purchase engines from? Any info would be great..
jaredfolks@msn.com
jaredfolks@msn.com
ok PLEASE, and i repeat PLEASE use the search function since you are new to this site. this has been discussed 394275829330523 times. thank you
search is your friend. like trinity says, its been talked about a lot. but you might also want to check out the hybrid forum too.
just to start you off since i'm bored:
info on the b16 : http://tech.hybridgarage.com/
places to buy (there are a lot more, but a few off the top of my head)
http://www.passwordjdm.com/
http://www.hmotorsonline.com
http://www.importautosalvage.com/
and if you want people's opinion on where the best places to buy a motor is:
https://honda-tech.com/zerothread?id=50010
hope that helps.
[Modified by l0p3z, 11:22 PM 1/30/2003]
hope that helps.
Thanks for the info...Search is my friend yes i know thats how i got here..
Engine is coming out of the car tomarrow..Hope to have a b16a ordered by next week..Quick question..I bought this car for 58 bucks..had it for a week how can i tell what model it is ? i know its a 90 crx.Thanks again for the help
look at the motor...if its 16v multi port injection then its a si... if you dont see a 16 valve on the valve covor then its a hf...and if its 16 valve and its dual port then its a dx...someone can correct if im wrong but im almost posotive im right...and you should search but just to help you...look on http://www.hmotorsonline.com they have good prices for the b16 complete changover...but in short...ur gonna need full swap, mounts, linkage...
Thanks for all the info...Next question other then the mounts does it bolt right in? and what wiring will i have to re-do? if you have a website with that info it would be great....hehe I got the car for 58 bucks.Also what interior can i use that will bolt in? if i cant find anything i guess im just gonna weld some brackets in
JdM_HoNda
Jul 16, 2003 12:54 PM
