Do Ingalls camber kits stay at the correct angle?
Old Jan 30, 2003 | 07:06 PM
Racer X's Avatar
Default Do Ingalls camber kits stay at the correct angle?
Like I said in a recent post, I had my camber kit installed. I was wanting to know if they ever slip out of alignment and if they do, will most mechanics know what to do if I take it to them?
Old Jan 31, 2003 | 02:18 PM
Racer X's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (Racer X)
Has anyone heard if they slip outta place? I'm just a little anxious cuz I hear them squeaking that's all.
Old Jan 31, 2003 | 04:22 PM
Tweakmeister's Avatar
I've never heard of trouble with the Ingalls....but things can happen.
any mechanic should be able to correctly adjust it.
Old Jan 31, 2003 | 04:40 PM
IC x Prince's Avatar
New User
Default Re: Do Ingalls camber kits stay at the correct angle? (Tweakmeister)
I have never heard of the ingalls kits slipping. I have heard of a couple (maybe only one) of the skunk2 slipping, but I read that here on h-t..not in person. the ingalls are in my book.
Old Jan 31, 2003 | 10:16 PM
confucius's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (UltraPrince)
the only bad thing about ingalls are that they put two new dents under the hood.
right above where the ingalls are.
ingalls causes ur control arm to come in contact with metal above it.
pos.
Old Feb 1, 2003 | 05:43 AM
seiya's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (confucius)
I've had mine for 2 years. No slipping, no rubbing problems at all. lowered on 1.75 on stock shocks. They do get squeaky, tho.
Old Feb 1, 2003 | 07:45 AM
Turbo Dreams's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (seiya)
They can slip. Also, the can put bend marks in the shock towers. Sometimes they make different noises too. Just don't go too low.
Old Feb 1, 2003 | 11:33 AM
HondaJon's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (Turbo Dreams)
Any camber kit has and will slip with enough abuse on them.
You're better off running like -2 if you're tracking the car, rather than having to worry about the alignment slipping or having some complications with a camber kit at the limits of driving.
JP
Old Feb 1, 2003 | 12:52 PM
Racer X's Avatar
Default Re: Do Ingalls camber kits stay at the correct angle? (HondaJon)
I'm not auto xing the car, I just didn't want tire wear, which was occuring after 6 months. So should I be okay if I just do the occasional 1/4 mile runs at the track?
The Si
Oct 14, 2006 11:51 AM
DA is best
May 11, 2006 12:10 AM
lowezz
Nov 18, 2004 10:14 AM
Viva la Nubz
23
Jan 31, 2004 11:35 AM
eTec
19
May 21, 2002 04:51 AM
