Motor mount question
Old Jan 30, 2003 | 05:28 PM
Briman2021's Avatar
Default Motor mount question
I know that aftermarket motor mounts are generally stiffer than stock, and the helps keep the engine in place, but what good does this actually do??
does it help acceleration, or handling, or what??
also, i dont know if you have heard of the "window urethane" trick, but if any of you have experienced it first hand, does it make the car vibrate a lot more, and how safe is it??
Old Jan 30, 2003 | 05:29 PM
-Whitey-'s Avatar
Default Re: Motor mount question (Briman2021)
motor mount inserts are supposed to help with traction..what is the window trick?
Old Jan 30, 2003 | 05:38 PM
Briman2021's Avatar
Default Re: Motor mount question (FF-Panda)
I guess you use window urethane (kind of a glue/epoxy stuff from what i ahve heard) and you let it dry in your motor mounts, and it dries really hard, so it works like a hard motor mount insert.
I dunno if all this is true, but my friend told me that he did that trick on one of his cars, so this is what i think you do.
Old Jan 30, 2003 | 05:41 PM
freakin_eLRoD's Avatar
http://www.homemadeturbo.com has explanations on the urethane window sealant stuff.
Old Jan 30, 2003 | 06:50 PM
NonovUrbizniz's Avatar
Loved
Default Re: Motor mount question (powerBan.est1990)
I just did the motor mount inserts... and they stiffen up the engine A LOT.. this reduces wheel hop and trasfers power to the ground more efficiently and quickly.
It's REALLY REALLY rattley right now though and I didn't even do the rear mount. but it'll probobly lighten up after they break in.
and just fyi... the inserts are ONLY the lower mounts not the two upper mounts that you can see from the top on engine. to change these mounts you have to get at them from under the car and it's kinda a bitch but as with honda... not that bad.
Old Jan 30, 2003 | 07:33 PM
Briman2021's Avatar
Default Re: Motor mount question (NonovUrbizniz)
I think I will do the home-made route.
How hard is it to remove motor mounts, and If I do them one at a time, can I leave the engine in while I am doing it (the car will be parked and not driven of course)
Old Jan 30, 2003 | 07:37 PM
soslow93's Avatar
man just break down and spend the 40 bucks it deffinetly worth you time to just slip them in it took me by myself and a little jack basic handtools about half hour.have not done rear yet still a little cold to lay on ground .trust me youl love them if you know what you want them for ..very simple one of better things done to date..
Old Jan 31, 2003 | 06:08 PM
Briman2021's Avatar
Default Re: Motor mount question (soslow93)
would you recommend them for a daily driver, or would they cause too much vibration??
Also, what brand would you recommend, i have a 97 ex coupe with d16y8 motor.
Thanks!!
Old Jan 31, 2003 | 09:17 PM
delslow94's Avatar
i got the es mounts and love them...they are definatley ok with street driving unless ur a baby about it. the vibration is noticeable but its really not that bad...the steering wheel will vibrate a good amount tho. definatley go with the es mounts.
90si-rex
Nov 17, 2008 12:00 AM
steveharrmr23
May 1, 2008 08:34 AM
kcirdnek
Oct 6, 2004 10:29 AM
B_1_8_hatch
Feb 17, 2003 06:50 AM
W.O.T.
Aug 28, 2002 01:52 AM
