does anyone have there a/c and or heat removed from a 90-91 dx hatch?
Old Jan 30, 2003 | 03:41 PM
4ghatch's Avatar
Default does anyone have there a/c and or heat removed from a 90-91 dx hatch?
i was just wonduring how heavy this stuff is to see if its worth it realy. I know im romoving the a/c but unsure of my heat. If the heat comes out it more for the space for gauges. So let me know if you can help out. thanks alot
Old Jan 30, 2003 | 03:46 PM
Hondasaurs's Avatar
Default Re: does anyone have there a/c and or heat removed from a 90-91 dx hatch? (4ghatch)
I pulled out my AC. The compressor and its bracket has a little weight to it. Don't remove the heat if you ever plan on defrosting the windoes.
Old Jan 30, 2003 | 03:55 PM
4ghatch's Avatar
Default Re: does anyone have there a/c and or heat removed from a 90-91 dx hatch? (ZC_CRX)
"a little weight"??? You dont know how much? and my car will not be a daily driven car so i should be ok with out heat
Old Jan 30, 2003 | 11:13 PM
TypRice's Avatar
i pulled my ac out , because the turbo kit would not fir with it in...not much weight...but every ounce counts!
Old Jan 31, 2003 | 12:51 AM
FullMetalJacket's Avatar
Default Re: does anyone have there a/c and or heat removed from a 90-91 dx hatch? (TypRice)
the ac and brackets and the piece under the dash add up the lbs...keep the heat wiping fog of the windows while drivin is a pain in the ***
Old Jan 31, 2003 | 02:53 AM
89dxhunchback's Avatar
Default Re: does anyone have there a/c and or heat removed from a 90-91 dx hatch? (FullMetalJacket)
Mine worked, I pulled it out for weight, but didn't save much... If it works, and you ever see over 80 degrees, I'd leave it in..
TurboTagTeam
Oct 1, 2004 07:44 AM
DerangedEG
Feb 10, 2004 11:32 AM
FourthGenHatch
Jul 13, 2002 06:56 PM
Rhetoric
Oct 6, 2001 01:54 PM
