installed skunk gears dont know which part is UP when at TDC
Old Jan 30, 2003 | 12:26 PM
whitelightning's Avatar
Default installed skunk gears dont know which part is UP when at TDC
mated with my 00-01 cams, what would be considered the UP markings on the cam gears...the one with the markings????
any help is appreciated.
Old Jan 30, 2003 | 12:35 PM
sgT's Avatar
sgT
Default Re: installed skunk gears dont know which part is UP when at TDC (whitelightning)
usually
but you should use the side markings and not the up markings
Old Jan 30, 2003 | 12:36 PM
Dave-ROR's Avatar
Default Re: installed skunk gears dont know which part is UP when at TDC (sgT)
usually
if you want TDC on #1 the side markings should match and the TDC mark on the crank pulley will be right on (assuming you know where the mark is and where to line it up at)
Old Jan 30, 2003 | 01:02 PM
Default Re: installed skunk gears dont know which part is UP when at TDC (FyrStarter)
hmmm, i know where all the markings are, I've set the crank at #1 by lining it up with the mark on the block, but my cam gears if the lines are considered the UP then i f*cked up...b/c i had them pointing at eachother at the side for TDC. guess this is why my car is not starting up
Old Jan 30, 2003 | 03:28 PM
mts20k97's Avatar
your distributor could be 180 out of time, make sure it is on the right way. just a thought
Old Jan 30, 2003 | 03:55 PM
SurferX's Avatar
On my Skunk2's, when cylinder 1 is at TDC, the degree markings are on top, they aren't facing sideways if that's what you are saying yours are doing.
Bayareasfinest
Oct 7, 2010 03:07 PM
ketchup
Feb 8, 2009 09:08 PM
qazaq
Jun 9, 2007 03:58 AM
Black R
Jul 20, 2002 10:31 PM
