valve cover
Old Jan 30, 2003 | 12:12 PM
One2chi's Avatar
Default valve cover
ive never taken off my valve cover before and im scared to do it....i dotn know anyhtign about it either....do i have to drian the oil to do it? how hard is it to take it off/get back on.....any tricks or things to remember? thanks.
Old Jan 30, 2003 | 12:41 PM
One2chi's Avatar
Default Re: valve cover (One2chi)
cmon i knwo one of you has taken it off before....
Old Jan 30, 2003 | 01:14 PM
JimBlake's Avatar
Its really easy, you don't have to drain your oil. Just get the spark plug wires out of the way & take off a bunch of small bolts/nuts.
Unless your car is fairly new you might want to have a new gasket & spark plug seal rings. After a few years the old gasket isn't gonna be real soft any more, then it won't seal when you put it back on.
Why do you want to take it off?
Old Jan 30, 2003 | 01:22 PM
Old Skool's Avatar
Default Re: valve cover (JimBlake)
when you put it back on it doesnt have to be super tight because the valve cover studs can break off very easily, trust me..it isnt fun. check in your chiltons or helms manual for tightneing specs (should be around 7 ft-lbs.
Old Jan 30, 2003 | 04:22 PM
Bantam's Avatar
2nd Coolest Person in DFW
Hey, it is as easy as hell to do, get a new gasket, and some gasket sealer and go after it
Old Jan 30, 2003 | 04:55 PM
Desslok's Avatar
Default Re: valve cover (F**KTheSystem!)
Yes 7 lbs. I broke to of the studs, thinking " I'll jus tighten them down like spark plugs. Cost me about $15 for the studs.
Old Jan 30, 2003 | 06:30 PM
One2chi's Avatar
its all grimy and **** wanna clean it and possibly paint it black
Old Jan 31, 2003 | 05:16 AM
Charlie Moua's Avatar
-take off grounding wire
-take out spark plugs
-take off spark plug wires
-take off about 4-6 bolts (depends on which f22 you have)
-optional----take off oil cap so that you can pull it off with you finger in it)
slowly take it off you do not want to rip or damage the rubber gasket.
if the rubber is really hard and sorta brittel you might as well spend about 15 buck and get a new valve cover gasket set at you local honda dealership.
HTH
[Modified by Charlie Moua, 8:16 AM 1/31/2003]
Jax4gencivic
Mar 24, 2006 06:49 AM
[HrZn]4life
May 13, 2003 09:30 PM
ludesleeper
Feb 21, 2003 12:10 PM
confucius
Mar 26, 2002 07:39 PM
FSTRex
Oct 5, 2001 09:07 AM
