Question about milled head and cam timing?
Old Jan 30, 2003 | 11:19 AM
cruzersi99's Avatar
Default Question about milled head and cam timing?
If my b16 head is milled .3 to increase comp to 11:1 what effects does that have on cam timing?
Where is 0,0 going to be on the cam gears?
Thanks,
Cruzer
Old Jan 30, 2003 | 11:20 AM
sgT's Avatar
sgT
Default Re: Question about milled head and cam timing? (cruzersi00)
.3 what?
Old Jan 30, 2003 | 11:43 AM
cruzersi99's Avatar
Default Re: Question about milled head and cam timing? (sgT)
I believe it is .3mm SGT. as .3 inches would result in way more the 11:1 compression.
thanks,
Cruzer
Any tips for passing CA Smog with the following setup:
Icebox
JDM 4-1
Spoon TB
ITR Intake Manifold
CTR Cams
11:1 Compression (VIA MILLED HEAD)
2.5" Cat with Hi-flow carsound cat
I failed at the following settings:
43 Fuel Pressure at WOT
12 Timing
Cam gears at +2, -1.8
I have since changed to 40 PSI
8 Timing
and -1,-1, but I think I may need to go to +1,+1 to reduce overlap.
I am having trouble at 15mph
Max/ave/Measer
HC 65/9/118
CO .56/.02/.98
NO 484/57/1473
at 25 I pass
HC 49/7/49
CO .55/.03/.06
NO 771/50/332
Thanks,
Cruzer
Old Jan 30, 2003 | 12:21 PM
Sleeper's Avatar
+1 degree per .3mm or .012" removed.
+1,+1
Old Jan 30, 2003 | 12:26 PM
Sleeper's Avatar
"and -1,-1, but I think I may need to go to +1,+1 to reduce overlap."
Overlap is the same with either -1,-1 and +1,+1. Decrease overlap by retarding the intake and advancing the exhaust. Increase is opposite, advance intake, retard exhaust.
Old Jan 30, 2003 | 01:08 PM
cruzersi99's Avatar
Default Re: Question about milled head and cam timing? (Sleeper)
Basically, I just want 0 and 0.
If I am reading correctly 0,0 will be =+1,+1
Cruzer
Old Jan 31, 2003 | 03:54 AM
Sleeper's Avatar
Correct.
neofreak
25
Jan 1, 2007 12:33 PM
lilredhatch
Jun 1, 2004 05:19 PM
tinkerbell
Oct 20, 2002 09:52 AM
Rhetoric
Sep 11, 2002 10:02 PM
