USDM better than JDM itr ecu?
Old Jan 30, 2003 | 08:50 AM
Propulsion's Avatar
Default USDM better than JDM itr ecu?
I swear I heard this somewhere, could someone confirm this? and tell me why this is?
Old Jan 30, 2003 | 08:55 AM
sgT's Avatar
sgT
Default Re: USDM better than JDM itr ecu? (SilverCIVIC96)
i doubt its that much better
gary201147's Avatar
Its JDM; its automatically better
Old Jan 30, 2003 | 09:15 AM
Philly_NBP_R's Avatar
well the JDM ecu is probably calibrated to run on higher octane fuel, which is pretty much standard in JDM land - the USDM ITR ecu is set for 92 octane or better, so that would probably be a better choice - why not ditch them both and get a reprogrammed p28? or a Hondata???
Old Jan 30, 2003 | 09:24 AM
Padawan's Avatar
Darth ModerVader
Default Re: USDM better than JDM itr ecu? (Philly_NBP_R)
Maybe he likes his knock sensor
Old Jan 30, 2003 | 09:36 AM
Propulsion's Avatar
Default Re: USDM better than JDM itr ecu? (Padawan)
I am also considering the reprogramed p28, Im just afraid that they dump too much fuel, and lead to bad gas milage and carbon deposits... any thoughts?
Old Jan 30, 2003 | 09:38 AM
sgT's Avatar
sgT
only if you get an open loop program like mugen
Old Jan 30, 2003 | 09:40 AM
YumVTEC's Avatar
i have a skunk2 chipped p28 and yes, it does run EXTREMELY rich without any other tuning. that doesn't mean you shouldn't get a chipped p28 though. the chip is just a baseline program that you can tune from using a VAFC or other air/fuel controller.
Old Jan 30, 2003 | 03:26 PM
Propulsion's Avatar
Default Re: USDM better than JDM itr ecu? (YumVTEC)
well, lets do some math,
obdII-I harness 200
p28 chipped ecu 250
vafc 250
total $700
how much more is hondata???
Old Jan 30, 2003 | 04:22 PM
gsr-2nr's Avatar
Default Re: USDM better than JDM itr ecu? (gary201147)
the jdm 1 is better
Old Jan 30, 2003 | 04:32 PM
nortrop's Avatar
I got rid of my JDM ECU because of the speed limiter it had. As I understand it, USDM ECU's do not have a speed limiter. I'm running a chipped p28 and the limiter is no longer an issue.
Old Jan 30, 2003 | 06:50 PM
skafia's Avatar
25 Year Member
Default Re: USDM better than JDM itr ecu? (nortrop)
Yeah JDM ITR's are governed at 118 MPH Sucks hehe.
Old Jan 30, 2003 | 06:56 PM
SurferX's Avatar
Why would you even consider an OBD1 P28 if you were just going to use a VAFC? They work fine on OBD2 cars.
Old Feb 1, 2003 | 12:25 PM
2fknlo's Avatar
Default Re: USDM better than JDM itr ecu? (SurferX)
Is there a difference in RPM limit from the two?
Old Feb 2, 2003 | 09:06 AM
scooter's Avatar
Default Re: USDM better than JDM itr ecu? (2fknlo)
I dyno'd back to back the USDM and JDM ITR ecu and gained 5-7hp everywhere with the JDM R ecu. Also I was running 93 octane and no other changes made inbetween runs.
I only got rid of the JDM ecu because I went boost otherwise I would have kept it.
scott
Old Feb 2, 2003 | 11:14 AM
azn98R's Avatar
obdII-I harness 200
p28 chipped ecu 250
vafc 250
total $700
Like another $200
the difference is the vafc 250 ~ 300 the hondata I bought mine for 450.
Old Feb 3, 2003 | 05:28 AM
ianp's Avatar
I have a JDM ITR. According to the tack, I hit the rev limiter at just over 9100, I noticed the day I let my mate have a drive, he drove it like a wusss till I told him to floor it, he then promptly hit the limiter.
PS The speed limit has been bypassed so I dont stop at 112mph or what ever it is, dont know if this upgrade increased the RPM limit as it was done b4 I got the car.
Old May 10, 2007 | 04:24 PM
Agent_EM1's Avatar
Default Re: USDM better than JDM itr ecu? (ianp)
Good Information on this old Thread
PHEDROTTO
Engine Management and Tuning
Feb 4, 2011 09:33 AM
racebum
Jan 14, 2009 01:48 PM
Parada
Nov 11, 2006 06:27 PM
Dragger817
Dec 22, 2005 05:27 AM
RedheadRacing
Sep 10, 2002 07:27 AM
