GSR Skunk2 Manifold Question
Old Jan 29, 2003 | 08:50 PM
StinkyTofu's Avatar
Default GSR Skunk2 Manifold Question
I haven't come around to install this on my car yet. I talked to my friend earlier about it and he said he was still wondering what he should do with an extra coolant passage at the back of the manifold. He said he just connected a tube to it and plugged it. It works fine but he's worried the plug might come off. Is that you guys are doing too?
Also, i bought the upper and lower pcv tubes listed in the instruction manuals. However, do i need to buy a pcv valve tube to connect to the manifold? Or can i reuse hoses off the stock manifold?
Just trying to prep as much as possible to get a clean skunk2 intake manifold installation.
Old Jan 29, 2003 | 09:15 PM
SMZ GSR's Avatar
Default Re: GSR Skunk2 Manifold Question (StinkyTofu)
Hey Tim, maybe this can help you
http://www.jdmhondaparts.com/tech/sk2manifold/
Old Jan 29, 2003 | 09:20 PM
StinkyTofu's Avatar
Default Re: GSR Skunk2 Manifold Question (SMZ GSR)
Thanks. That site is pretty in depth on how to install it. But isn't installation slightly different between '94-'95 GSRs and '96-'01 GSRs?
Old Jan 29, 2003 | 10:09 PM
B18EG6's Avatar
I have one on a 95 gsr...i dont recall there being an extra coolant hole...is there on the newer ones?
doesnt hondata make an IM gasket, and has a place where you can cut a hole for the coolant, if need be?
im confoosed, help me out
Old Jan 30, 2003 | 12:47 AM
M-Type's Avatar
Default Re: GSR Skunk2 Manifold Question (B18EG6)
just use a T fitting to connect the two
Old Jan 30, 2003 | 12:48 AM
M-Type's Avatar
Default Re: GSR Skunk2 Manifold Question (M-Type)
ask Sukebei Oni for more info. he just put one on the other day
Old Jan 30, 2003 | 07:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
One step in those instructions shows this pic:
The 94-95 GS-R intake manifold doesn't have this sensor. Does Skunk2 make 2 different manifolds for the different year vehicles, or is something else done for this sensor when installing the Skunk2 manifold?
Old Jan 30, 2003 | 07:53 AM
AK94GSR's Avatar
Default Re: GSR Skunk2 Manifold Question (PatrickGSR94)
Yes, 94-95 GSR's have this. I put mine on a while back and had no problems. Everything hooked up from one manifold to the other. as far as newer tegs....you will need to T one of the coolant lines.
Old Jan 30, 2003 | 09:20 AM
Community Builder
Default Re: GSR Skunk2 Manifold Question (AK94GSR)
ohhh wait sorry, I was thinking of the wrong thing... I know the newer teg manifolds have an extra piece on top of the manifold that the older ones don't have... is that what you were talking about, having to T into a coolant line?
blackhbkid
Feb 5, 2009 07:50 AM
SHG_EasyE
Feb 26, 2005 12:35 AM
egjdm03
Feb 11, 2004 09:05 AM
Vteg02
Aug 15, 2001 07:43 PM
