newbee Q about dragrace.. tire pressure, size ETC
Old Jan 29, 2003 | 06:45 PM
Zeus Zore's Avatar
Default newbee Q about dragrace.. tire pressure, size ETC
Hey..
well what is the best tyre pressure for dragrace with goodyear 195/50/15
i heard low is good but how low ?? witch brings the next Q up..
i goin for slicks tyres.. what size ??
i understand that the 60 ft is impotent for a good 1/4 mile !
have do you get that "right" start ??
i have a 95 EX/si civic
thx !!.. hopin for some good info !! thx
Old Jan 29, 2003 | 07:40 PM
tractionbar2nr's Avatar
Default Re: newbee Q about dragrace.. tire pressure, size ETC (Zeus Zore)
don't know too much about running on street tires.. i would have to guess and say try setting your tire pressure at about 20lbs and play with it from there. + or - it all depends on the track and track temp. try to drive around the water box if you are running street tires. reason being is that you are just going to drag all that water with you up to the starting line within your tread.
60 ft is important but just get used to driving on the track and it is all about practice. go to the track every friday night or when ever your local test and tunes are and just run the car. make notes if you have to and see where your car likes to be launched and what tire pressure and things of that nature.
as far as slicks... what do you have done to your car? how much power are you putting down and what motor and trans are in the civic?
Old Jan 30, 2003 | 05:09 AM
Zeus Zore's Avatar
Default Re: newbee Q about dragrace.. tire pressure, size ETC (tractionbar2nr)
i have a 140 FHP in my D16Z6 and header and catback and a airintake + act clutch and fidenza flywheel
20 LBS ? what is that in PSI ?
thx
[Modified by Zeus Zore, 8:16 AM 2/1/2003]
Old Jan 31, 2003 | 10:16 PM
Zeus Zore's Avatar
NO Help ?!! no one knows about these things ?
come on !!
Old Jan 31, 2003 | 11:00 PM
xSpooNxEkx's Avatar
he's saying 20 psi (pounds per square inch) and with 140 hp and maybe a none lsd tranny it's pointless putting slicks on... if you do get 13".... what do you have in your single cam? mines was built and i only pushed out 147 hp
Old Jan 31, 2003 | 11:08 PM
Default Re: newbee Q about dragrace.. tire pressure, size ETC (xSpooNxEkx)
well if you wanted to run slick i would say go with no bigger than a 22x8x13. you should be able to spin those. but as far as improving in the 1/4 mile... just take your car to the track every chance you get and just try new things and make notes on what worked and what didn't. i'm sorry i can't be of more help. i haven't ran a street trim car in years.
Old Feb 1, 2003 | 08:27 PM
Zeus Zore's Avatar
it is 140 flywheel HP !!.. we dont do much in WHP here !!
what have you done 2 your sohc ?! 147 HP is OK !!.. whta parts ??
so i should not worry about slicks ?? since im fare from 140 WHP !..?
Old Feb 1, 2003 | 11:50 PM
ExospeedAMcrx's Avatar
if you are below 140HP to the wheels.. I'd suggest trying the 20x8x14 first and get used to that. pushing 13x22x8 is a bit tricky and you have to know what you are doing. there are going to be some factors that you need to take care of if you want to run the 22x8x13 with only that much HP.. one would be.. pump up the slick normal than usual.. since most likely, you'll have to focus more on that slick being as pumped up as possible so it can roll at the end of the track.. or else you wont be able to push it at the top end... ya understand?
kte324
Sep 28, 2010 08:13 PM
AK94GSR
Feb 9, 2004 02:19 PM
flip1199
Jan 13, 2003 02:27 AM
momo48
Jan 23, 2002 06:25 PM
