upping the y8 compression with d16a1's?
Old Jan 29, 2003 | 06:01 PM
tinkfist's Avatar
Default upping the y8 compression with d16a1's?
i am not exactly sure what the stock y8 compression is (10.?:1), but i have been reading about upping it with d16a1 pistons to 12.6. i know this is pretty high, so what kind of mods are needed to use this power without a blowout (cams, timing, etc)? also, can you still run 91-94 octane on this?
anyone that has these on their y8, i would like to hear your options.
Old Jan 29, 2003 | 06:05 PM
poison's Avatar
Default Re: upping the y8 compression with d16a1's? (tinkfist)
yep. that's correct. it really depends on what altitude you are at however.
I have a friend running ls/vtec with 13:1 CR at 4500 ft elavation, running on 91 octane and timing is not retarted at all...
that is the strangest I have seen.
if it pings, just dump more fuel in, go higher octane or retard ignition timing.
[Modified by poison, 8:06 PM 1/29/2003]
Old Jan 30, 2003 | 05:57 AM
tinkfist's Avatar
bumping this up for the day time techies...
peace.
Joey Mitchell
Nov 19, 2018 11:53 AM
roachsboosted16
Jan 25, 2009 07:41 PM
zcrx2006
Nov 29, 2007 07:25 PM
99hatch
Feb 1, 2005 08:36 AM
JonGP4
29
Nov 21, 2003 10:35 PM
