Power lock to manual conversion
Can somone help me find the post that had pic's, diy, and part numbers to convert the locks. I've been searching, but can't come up w/ the right words to find the post.
thanks in advance
thanks in advance
ant-theft measure. I just read on a website how easy it is to get into Honda's by by prying the weather stripping and window to slide someting down an tap on the power lock
You're not disabling the power locks, you're removing the silver lock tab that is easily reachable by the method you mentioned.
You need RS door handle bezels, about $7 each from the dealer.
Pry out the screw cover on your current bezel, take out the screw, and remove the existing bezel, being careful to note how you fed it around the door pull handle. Unplug the lock tab mechanism and tape it behind the door panel.
Reinstall the RS bezel in the reverse of the original. Your power locks will still function, but you won't have the silver tab to actuate them. Some folks have wired in an alternate switch somewhere. Best I've seen is to use a GS-R sunroof switch in the factory location.
Sell your Hype R bezels to some ricer who thinks they're special.
Just unplug the switches and leave them in so the thieves will waste their time trying to figure out wat's wrong..so you can run up on them and beat them.
There's slim jim designed to open up hondas (and others) regardless of the kind of door locks..but I'm not gonna get into that..
[Modified by WundedSaint, 4:09 AM 1/30/2003]
Seriously though, it would be pretty cool to have something wired up to it...couldn't be that hard!
) About protecting the lock mechanisim. responding a guy with a 95 EX who got broken into.If you cant find the post, e-mail me.
Mike
lilLB
Apr 21, 2006 07:19 PM
BolivianFuego
Nov 18, 2004 09:16 AM
zertoir
Apr 12, 2004 08:46 PM
Drinker
