Adjusting Clutch Engagement
Old Jan 29, 2003 | 03:39 PM
steve_s's Avatar
Default Adjusting Clutch Engagement
The clutch on my 93 Civic EX is a little high, meaning it engages about 2-3 inches from the floor. Is there any way to make it engage earlier?
Old Jan 29, 2003 | 03:51 PM
Kataku2K3's Avatar
Default Re: Adjusting Clutch Engagement (steve_s)
Take a 12mm open end and unlock the locking nut that holds that rod that pushes the piston in on the clutch master cylinder. Once you have the nut loose spin the rod counter clockwise (that will be if you are working on it from under the dash, NOT if you are upsidedown with your head against the firewall.. Anyways just spin it out however much you want till you have the correct engagement point... Don't do it too much or you'll put preload on the clutch.. If you need anything else lemme know... Peace
Old Jan 29, 2003 | 03:57 PM
steve_s's Avatar
Default Re: Adjusting Clutch Engagement (Kataku2K3)
So am I adjusting it from under my dash or in the engine bay?
Old Jan 29, 2003 | 04:37 PM
Kataku2K3's Avatar
under the dash.... right behind the pedal where the rod goes through into the master cylinder... Good Luck
krysted9354
Dec 30, 2008 09:19 PM
D16Clunkin
13
Dec 22, 2006 05:43 AM
redsikiller
Dec 2, 2005 08:58 AM
MechEng
Jul 16, 2005 12:06 AM
