removing rust
when welding the muffler tip to the the muffler there were some flicks of weld that got onto the stainless muffler..after time they began to rust..any idea s re. removing the rust spots?
there is some rust eater that can convert it back to metal, then sand it off with some fine grit paper, or you can paint it with chrome painting if you wish to hide it, or flat black
If its not that bad then some light steel wool would work ok. If its starting to build up your goina have to get a brush to it.
Good way to keep it from coming back is to take it to a place and have them chrome it (That is if the welds are done fairly well, or rust will start in the holes of the weld and spread out)
doubleoazn03
Jan 25, 2011 07:24 PM
Brewer
Jan 28, 2003 02:09 PM
